Introducing TotalLoadControl Suspension for 09-12 RAM 1500 - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 11-02-2011, 01:08 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Satisfied Customer Email
Here's a picture and an email from a satisfied customer sent to our inventor, Vern Mullican.
Hi Vern –
I got your telephone invitation to meet y’all in Phoenix this weekend – thanks.
I’m working high atop Mt. Alison, overlooking San Jose California for a couple of weeks – so I won’t be able to make it to Phoenix. Damn –
Since the last time we spoke, or corresponded, I have put the rig to a real test. The attached photo shows how it looked the other day on my way out here – 1800 lbs car, the two gang boxes up front on the trailer weighed about 350 lbs each, and I had the bed of the truck completely filled with another 600 lbs or so.
Despite all that load, I ran only about 30 psi to level the rig and provide a silky smooth ride – the system works very well.
After I got here, I off-loaded the car and gang boxes, then proceeded to haul a variety of loads up to the top of this mountain – only 2400 feet or so, but a short, rough, dirt road all the way. The heaviest was thirty 19.5’ sections of 6” transmission line, total 3600 lbs. No issues there either – 30 psi and 4-wheel drive made it all easy.
BTW, I did meet a guy at a gas station in Needles, hauling a GTO back from a show in ‘Vegas, with a butt-sagging Ram 1500 up front – I had him crawling under mine to see the magic – I gave him your name and told him how to reach you – hope you made a sale.
Anyway, I am completely satisfied with my TLC system – thanks again
Chuck
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 11-03-2011, 09:40 AM
WhenInDoubt101 WhenInDoubt101 is offline
Vehicle: 2011 Ram Bighorn 4X4
WhenInDoubt101 is on a distinguished road
Hey John, I purchased the TLC for my 11 Ram 1500 from you as well. Everything works very well, with the 800lbs 24/7 in the bed my truck was sitting even, now with the click of a button and 10PSI my truck sits like the day it came out of the factory. I can't wait to pull a trailer, I think this is really going to work for any weight application with in reason. The install instructions made it really easy except for me be being anal, the only thing I didn't like was the gauge cluster and I'm not sure what you could do to make it better. I took the gauge cluster apart and mounted everything in dash and am completely happy with your product.
Thanks again,
Stan
Just Me.
Old 11-03-2011, 05:33 PM
John, I can't seem to PM you and I don't have a email address to send those photo's. I can post them here if you would like?
Just Me.
Old 02-17-2012, 03:21 PM
Ramajama's Avatar
Ramajama Ramajama is offline
Vehicle: 2018 RAM 2500 POWER WAGON
Trim Level: POWER WAGON
Color: Granite/Black
Rep:79
Ramajama will become famous soon enough
Hello John,
Thanks for the PM and heads up on your TLC system. I cant send PMs yet so I thought I'd respond here.
I noticed the compressor kit. Is this manual operation from the the gauge/switch unit or does this have auto leveling capabilities? I guess there's pros and cons to both but it would be nice to set the "stock" level you want and have it auto inflate back to that level when it comes under load.
2015 Land Rover Dicovery Sport HSE Lux
Old 02-17-2012, 04:40 PM
TLC John's Avatar
Rep:17
Default Air Compressor
At the present time, we only offer the manually operated switch.
Since the TLC system operates at low air pressure (5-8 psi unloaded and 15-20 psi loaded), it doesn't require much time to inflate. Our customers seem to enjoy the control that a manual switch affords.
Other systems may require up to 100 psi and much more time to inflate the bags. Other systems also require small amounts of air to prevent the air bags from breaking so the self-level may be a way to address that. TLC air bags cannot break because they are only mounted at one end and therefore free to inflate and deflate.
Thanks for the question. Please stay in touch.
Total Load Control™
Old 02-17-2012, 05:47 PM
Ramajama's Avatar
Rep:79
So..if you want, you can completely deflate your bags? The bags I have delt with in the past needed a constant 10lb minimum...then inflated to level was load was on.
Old 02-17-2012, 11:28 PM
TLC John's Avatar
Rep:17
Default Deflating TLC Air Bags
Yes, you can deflate the air springs completely and the air springs will not be damaged. However, there may be a clanging noise when driving over rough roads or bumps as the top of the air springs hit where the jounce bumpers were.
That's why we recommend 5-7 psi to inflate the air springs to avoid the noise (and also improve handling).
Our customers always keep air in the air springs for the performance improvement.
Total Load Control™
Old 02-18-2012, 12:54 PM
Ramajama's Avatar
Rep:79
OK, I got you. Thanks!
Old 02-22-2012, 11:56 PM
SawdustJ's Avatar
SawdustJ SawdustJ is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:22
SawdustJ is on a distinguished road
Hi John,
Any plans to to offer a more custom guage mount? Perhaps a pillar mount or something in or around the instrument cluster? Although this is a "bolt-on" system, I'd much rather it be seamless in the interior.
JJ
Mods: Extang Tri-fold Soft Tonneau Cover, Bed Liner, Volant CAI, Cabin Air Filter
Old 02-23-2012, 12:47 PM
llsht14's Avatar
llsht14 llsht14 is offline
Vehicle: 2015 Ram Power Wagon
Rep:25
llsht14 is on a distinguished road
Any Plans for making this work on my 6" lifted 2011 ram?
2011 Ram 2500 Laramie Megacab Cummins, afe intake, h&s egr delete, flo pro 5" turbo back exhaust, 6 in tip, mini maxx tuner
Sold--- 2011 Ram 1500 Sport
2500 and 1500 Differences?? hotchiliram 2012 Dodge Ram Forum 13 08-19-2011 03:11 AM
Dudes please help me out!!! 2010 cummins vs 1500??? Elite Cummins Diesel Specific Topics 31 07-25-2011 04:24 PM
1500 or 2500? PLEASE Help a New Member! bill440rt 2011 Dodge Ram Forum 34 07-02-2011 11:38 PM
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
