Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-28-2011, 03:46 PM
Bjoseph24 Bjoseph24 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Lonestar
Bjoseph24 is on a distinguished road
Default Running rough after oil change
My 2011 ram 1500 5.7 HEMI has 4,000 miles. This past weekend I changed the oil myself with Mobil One Full Synthetic Oil. Now my truck seems to be running rough. Could the oil change have done this?
Old 09-28-2011, 03:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Most likely not. You used the correct weight? (I think it's 5w20 but check your manual). You also changed the filter? The oil shouldn't cause an issue...
Sean
Old 09-28-2011, 06:42 PM
I used the 5w20. I'm hoping I didn't accidentally discount something under the truck.
Old 09-28-2011, 07:04 PM
snrusnak's Avatar
Rep:1385
Just how rough is it running? Oil pressure gauge seems normal?
Sean
Old 09-28-2011, 07:06 PM
The gas pedal has a lot of vibration when I'm accelerating. I dent notice it before the oil change.
Old 09-28-2011, 07:22 PM
snrusnak's Avatar
Rep:1385
Is it only a vibration in the pedal....but the truck seems to run/accelerate smoothly? I know that there are others(and myself) that have experienced slight vibration in the brake pedal from time to time, and I assume this same thing could be felt in the gas pedal...?
Sean
Old 09-29-2011, 09:14 AM
JimmyNichols's Avatar
JimmyNichols JimmyNichols is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
JimmyNichols is on a distinguished road
How many quarts of oil did you put in?
Old 09-29-2011, 01:35 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
Humm now this is weird, I just did mine this past weekend and I kinda noticed the same thing (as a matter a fact I said to my self this morning humm now that doesnt seem right!!), it just sounded different and felt rougher than before. I used 5w 20 full Syn oil and new filter, checked the dip stick 10 times oil level is on the full mark. Like always I filled the filter some. So I dunno I guess I will keep and eye on it and see how she runs after its warmed up good (run it park it then come back in a few and run it again.)
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 09-29-2011, 02:26 PM
P Rod's Avatar
P Rod P Rod is offline
Vehicle: 2011 Ram 2wd Crew Cab
P Rod is on a distinguished road
I just did my second oil change yesterday. 7 quarts of Mobil 1 5W20 with new filter. Did not notice anything weird. Drove 45 miles to work this morning and everything seems fine. As a matter of fact I just went outside and double checked everything again after reading this thread. I hope your vibbration is only temporary.
CrewCab Sport*Sunroof* Navi*3.92's*Ground Force 2/3 drop*Back Flip F1*Mufflex 18"*BedTred
Old 09-29-2011, 08:23 PM
SMOKINGRT SMOKINGRT is offline
Vehicle: 2011 dodge ram
Trim Level: rt
Color: grey
SMOKINGRT is on a distinguished road
anytakes on whats a preferred oil to change it to? looking to do my first oil change also but after reading this, not really sure if i should go with MB1, hows royal purple, herd if gives like an extra horse or two??
oil
first oil change manbearpig54 Dodge Ram General Discussion 6 09-27-2011 01:04 AM
first oil change today nikeman Oil Change 6 09-10-2011 08:38 PM
1st oil change: Syn vs. Conv? sporty11 Oil Change 31 07-11-2011 11:40 PM
Dif oil change believe or not? uktitus Dodge Ram General Discussion 1 05-23-2011 01:15 AM
RAM 1500 running rough chrismckenna Newbie Checkin! 16 08-24-2009 03:45 PM
