Old 09-28-2011, 07:12 PM
acelab1994 acelab1994 is offline
Vehicle: 2001 dodge ram 1500 4X4
Color: blue
acelab1994 is on a distinguished road
Default no second gear, please help
i have an "01 dodge ram 1500 4X4 with aprox. 145k miles on it, second gear went out not too long ago and i was told that it could be either the solenoid pack or the second gear band, i can fix both but i dont want to go blowing money i dont need to. any tips?
Old 10-02-2011, 04:45 PM
Terryserf's Avatar
Terryserf Terryserf is offline
Vehicle: 2001 Dodge Ram 1500 Quad LWB
Trim Level: Laramie SLT 4WD
Terryserf is on a distinguished road
I thought that my '01 was having low end power loss issues but after thinking about what was happening, I determined that it was a transmission issue. It would barely take off and when coming to a stop it would "roll" into neutral with a "thump". I realized that it was taking off in 3rd gear then not down shifting. It turned out to be the governor sensor and selenoid. Good as new ever since. hope this helps if you haven't solved your problem already. TS
If I don't see you in the future..... I'll see you in the pasture....
gear, help needed, second gear, transmission problems
06 hemi after the 1st gear adventurer 5.7L V8 Specific Topics 10 07-25-2011 06:45 PM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 01:23 AM
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 08:45 AM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 01:02 PM
rear diff philjohn 4.7L PowerTech V8 Specific Topics 26 06-27-2010 10:09 PM
