Old 09-28-2011, 06:20 PM
Luke243 Luke243 is offline
Vehicle: 2004 Dodge Ram 1500
Luke243 is on a distinguished road
Default moving muffler?
i currently have a super 44 flow master single in single out, with just the muffler at the end, no turn down or anything. My buddy had the same set up he got fed up with the annoying drone (like i am now) and got pipe bent for it to come out the back and 45 like the stock exhaust did, but now it dosent sound as throaty. if i were to move the muffler to behind the axle, almost like were the resonator was, and 45 it and have it come out would that run right? or sound better. In other words..
Take off the super 44 replace it with straight pipeing untill i get past the axle put the 44 back on and get a little more pipe and have it come out where the stock exhaust did.. Yay or nay?
Old 09-28-2011, 07:00 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You need more muffler to get rid of the drone...moving it wont change anything.
Old 09-28-2011, 07:37 PM
if i move the muffler back and have it come out the side will it sound better than if i kept where it is and ran pipe all the back to have it come out the side?
Old 09-28-2011, 07:53 PM
916Timmy's Avatar
Rep:1443
It might be a little quieter, but I am not sure. If you do a tip out the side or back, it will direct the sound away from the truck at speed
Old 09-28-2011, 08:13 PM
ORT's Avatar
ORT ORT is offline
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Moving it back will not eliminate the drone, but it might make it less noticeable since the muffler would be under the bed instead of under the cab.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-28-2011, 08:22 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Why not just put a turndown on it? Cheap to try. I've never heard if just having a muffler at the end if the exhaust system (unless we're talking about a riced-out civic or something.)
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 09-28-2011, 08:27 PM
ORT's Avatar
ORT ORT is offline
Rep:184
With the spare tire under the truck it would be tough to even fit the muffler behind the axle without it being in the way of lowering the spare.
Old 09-28-2011, 08:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
And although placement of the muffler in the system can slightly change sound, you won't get the results you're looking for by moving the muffler. For what you are trying to do(get rid of some drone, but keep some sound) I'd suggest just connecting a pipe from where the muffler is now and directing it towards the side of the truck (sort of like a side exit before the tire). If you don't want to see the tip you can end it a few inches before the body panel and put a 45 deg angle on it towards the ground. This should help with the drone, SOMEWHAT......
Sean
Old 09-28-2011, 08:52 PM
ORT's Avatar
ORT ORT is offline
Rep:184
Having run that same muffler on my 04 I don't think there is any complete solution to the drone problem other than getting a different muffler. The super 44 always droned on my truck whether I had the muffler dumper or pipes out the back.
Old 09-28-2011, 08:57 PM
snrusnak's Avatar
Rep:1385
sounds like it's time to upgrade to a straight through type
Sean
magnaflow muffler shrek Exhaust 8 11-05-2013 02:28 PM
Magnflow muffler just installed micjulmic Exhaust 3 08-17-2011 07:45 PM
Muffler Change = Reprogramming???? silverhemi03 5.7L V8 Specific Topics 6 01-27-2011 08:19 AM
mufflex single exhaust muffler part number H22A1 Exhaust 2 07-19-2010 12:54 AM
Magnaflow and Borla Muffler Fury 2010 Dodge Ram Forum 6 03-24-2010 08:27 PM
