Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-28-2011, 08:23 PM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
Default Air bag sensor
Does anybody know where the air bag sensor is located on a 2000 ram? Pictures if you have one would very helpful Thanks
Old 10-02-2011, 11:29 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I wish I had an answer for you; best I can do is this to the top.
Old 10-03-2011, 12:27 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I believe they are two small black box like sensors mounted under the hood just in front of the wheel wells on the flat horizontal surface, one on each side directly behind where the headlights are.
If you can't run with the Big Dogs, Stay on the porch.
Old 10-03-2011, 12:36 AM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Sounds right. The system has three sensors: two crash sensors at the front of the truck mounted along the inner fender panels behind the grille opening reinforcement and a safing sensor in the Airbag Control Module (ACM) located under the instrument panel, on the transmission hump.
Old 10-03-2011, 03:34 AM
Thanks for the info I needed to know where they were at so
I could troubleshoot my air bag system turned out to be something else
Old 01-16-2014, 07:14 PM
mplohrer151 mplohrer151 is offline
Vehicle: 2011 dodge ram
Trim Level: 3500
mplohrer151 is on a distinguished road
would anyone know where the crash sensor(s) would be on a 2011 dodge ram 3500?
P1128 p1129 firecadet613 5.7L V8 Specific Topics 9 03-06-2015 02:52 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
2009 Dodge 3500 SeaCaptain 2009 Dodge Ram Forum 4 10-10-2011 01:50 PM
XTRA POWER MOD moved IAC sensor from Manifold to Intake tube RAMING IT Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 05-09-2011 09:05 PM
over head console ram man Electrical 1 10-17-2010 01:41 AM
