obd error??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-28-2011, 09:20 PM
BigHorn4x4 BigHorn4x4 is offline
Vehicle: 2008 Dodge Ram 1500 Big Horn
Trim Level: SLT Big Horn
BigHorn4x4 is on a distinguished road
Default obd error???
had a Po440 for evap error, i did read most likely gas cap loose, any one have this issue at all? and how to fix it?? thanks!!!
Old 09-28-2011, 10:44 PM
moparornocar72's Avatar
Rep:630
More than likely yes it was gas cap, either it wasnt selaed all the way or the seal is just worn out on the gas cap. Clear the code and make sure it is tight, if it keeps coming back on i would change the gas cap and see if that helps, if not it might be a leak under the hood
14.268 @ 95 MPH Full Trim
Old 09-30-2011, 10:19 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
P0440 - Type Powertrain - Auxiliary Emission Controls - ISO/SAE Controlled Description EVAP Purge System Fault Conditions
Cause Engine at idle speed, ECT sensor input over 170°F, then the PCM commanded the EVAP solenoid open and closed and detected that the change in fuel compensation and in the IAC motor position were below a predetermined range
get a new cap and reset the PCM by disconnecting the battery for 20 min while the key is on position. Then shut off key and reconnect battery.
Old 09-30-2011, 11:07 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Could also be a dirty evap canister, or a faulty solenoid. I believe you can clean the canisters with compressed air. Try the gas cap first though as it's easy.
Sean
Old 10-02-2011, 07:49 AM
Rep:12
EVAP components are typically non serviceable units and the only fix is to replace it. What BigHorn4x4 has is a Faulty or loose Fuel Cap which causes Check Engine light to come on.
Determining Speedometer Error Due To Tire Size Change MADDOG Dodge Ram Wheels And Tires 16 01-04-2015 07:33 PM
Error code eliminators Niko Custom Dodge Ram Interior and Exterior Lighting 8 09-18-2011 01:08 PM
Computer Error RootBeer Jokes/Humor 13 02-16-2011 04:56 AM
Cortex error spihemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 08-13-2010 10:19 AM
