Old 09-29-2011, 02:05 AM
JayBones's Avatar
JayBones JayBones is offline
Vehicle: 2008 Ram 1500 4.7L Standard
Trim Level: TRX4 OFF ROAD
Rep:55
JayBones will become famous soon enough
Default Loose sidesteps. How to tighten?
My sidesteps on the driver side have come loose. I can feel the loose nut (bolt?) where it connects under my rear door and inside the door sill. Trouble is, I can't figure out where to access the part of the bolt inside the door sill. I could probably just google the instructions for the Mopar sidesteps, but that wouldn't give me an excuse to make a post on this forum...
So, can anyone help me out here? The rattling is starting to drive me nuts!
Thanks,
~Bones
Edit: I just realized I may be in the wrong sub forum. Mine's a third gen I guess. Maybe the process is the same? Or maybe a nice mod will move this where it belongs...
Bullydog GT GAS tuner, Diablosport Intune ordered, AVS vent visors, Line X under rail bed liner. BFG All Terrain T/A KO tires. Symbolic aluminum grille insert. K&N drop in filter
Old 09-29-2011, 06:35 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
you should just have to tighten down the bolts, i'm not sure if there is a nut on the end.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
Old 09-29-2011, 06:38 PM
As he ^^^^ said, just get that bolt threaded back in to the nutsert behind the panel and tighten it up.
Old 10-07-2011, 04:02 AM
JayBones's Avatar
Rep:55
Thanks... that's all it was. When I turned it with my fingers it just spun, but as soon as I actually used a socket, it threaded right in.
How to: Hood Insulation / Radiator Cover Graphic Designs 10ramisport Dodge Ram Knowledge Base 2 05-01-2014 01:25 PM
How to change disk brakes double0ram Dodge Ram Knowledge Base 16 05-25-2012 08:28 PM
Inside door handle loose Tankman62 Body & Interior 1 04-29-2011 10:39 PM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 01:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 11:44 PM
