Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 09-29-2011, 12:05 PM
jaywalker1172 jaywalker1172 is offline
Vehicle: 2004 dodge ram
jaywalker1172 is on a distinguished road
Default Gears and tuner for manual trans.
I know the gear topic has been done to death but i have yet to find a post with my specific truck. So hear goes.
I have a 2004, 1500, 4.7, 4X4, MANUALTRANSMISSION. I have the 3.55 gears and my tires are the stock 265's and don't plan on changing the tire size.
My question is- Would changing to the 4.56 gears with the stock tire size be to much? Or should I go with the 4.10's. I am changing mostly for the sake of towing. I don't race it and I am not a speed demon. I am mostly on a 55 MPH HWY. Towing about #6000. I noticed that most of the guys on here with 4.56's are running larger tires. Would my MPG suffer that much with the manual trans?
Also. Would a tuner do much for me having the manual? I thought they mostly just changed shift points in the automatic trans.
Thanks in advance for any answers guys.
Old 09-29-2011, 02:04 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Can you give your full tire size? Also do you know the specific name of the manual gearbox you have? That way I can look up the gear ratios and help you out...
A tuner would still probably give you about 15hp and 15 lb ft or so, but you won't get any other benefit as far as the trans goes. You would be able to adjust for rear axle gear ratio changes though, so that'd be a plus. There is also a tow tune that could help you out a little...
Sean
Old 09-29-2011, 02:08 PM
snrusnak's Avatar
Rep:1385
Is it a 5 speed manual? If so I think it's a NV3500...and if it is it looks like the final overdrive ratio is 0.73:1. If you're cruising at 55 mph and have 4.56 you should be fine. Post your tire size and I'll look into it a little more. And if you can figure out for sure what gearbox you have that'd help.
Sean
Old 09-29-2011, 06:29 PM
It is the 5 speed nv3500. And I am running 245/70/17's. Not the 265's like i previously stated. Thanks guys.
Old 09-29-2011, 06:42 PM
snrusnak's Avatar
Rep:1385
Ok your tires are about 30.5" diameter. Right now:
70mph = ~1998rpm
55mph = ~1570rpm
With 4.10:
70mph = ~2308rpm
55mph = ~1813rpm
With 4.56:
70mph = ~2567rpm
55mph = ~2017rpm
4.56 might be a little steep if you plan on cruising at 70mph+
Sean
Old 09-29-2011, 06:44 PM
snrusnak's Avatar
Rep:1385
Also, are you sure your truck can tow 6,000 lb? I'd double check, I think that manual transmissions can't tow as much as auto's, and my 2nd gen 4.7L with 3.55 can only tow like 6,250lb.
Sean
Old 10-17-2011, 02:52 PM
icywhite's Avatar
icywhite icywhite is offline
Vehicle: 04 dodge ram
Rep:29
icywhite is on a distinguished road
i have a 4.7 with 4.56s posi and i run 2.4 k at 70 and the truck pulls its ass off comparied to when i had the 3.55 opens you know how when you go up good size hills and have to down shift or the truck will start to slow mine no longer does that! i can start from 3rd gear if i want on a flat road lol when i put my 17s on now its like holy sh*t this thing gets moving im turning 305 35 24s with no problem if your towing a lot imo i would go with 4.56/4.10 posi, h.o. cams and a tuner and you wont have many problems that is an all tq set up
2/4 drop,h.o. cams,4.56s posi, stage 2 cai, 70mm tb, 180t, cutouts, efan, centerforce dual friction clutch,short throw shifter 24%, sct(tuned by flying ryan), high flo-Y, 3 inch exaust , jbl headers, 2013 intake manifold, nitrous, killian ported heads,leds and hids on all lights,
2010 Dodge Ram crew w/3.21 gears beating every Truck on the street!!! minus srt's&svt's lol miketen07 Drag Racing Discussion 26 10-29-2011 11:14 AM
1999 dodge ram 318 what gears? bigmikelrg 5.2L V8 Specific Topics 8 08-10-2011 09:44 AM
gears senate422 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 10-08-2010 02:04 PM
