Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-29-2011, 01:57 PM
hottpepp23 hottpepp23 is offline
Vehicle: 1999 Dodge Ram 2500 V10
hottpepp23 is on a distinguished road
Default A/C turns hot when braking
Ok what the hell...i need to hit up Xibit and pimp my ride. Hot air from air conditioning when I hit the brakes??? Help! Thanx in advance.
Old 09-29-2011, 03:48 PM
So in other words, as you slow, the A/C temp gets higher?
Well, the condensor does need some air flowing over it but you should not get hot air instantaneously. If you are, two things come to mind:
1. Your A/C condensor (mounted in front of your radiator) is plugged and needs to be cleaned. Some brake cleaner and warm water will do the trick. Don't hit it with a pressure washer.
2. If it stops cooling only when you hit the brakes (come to a stop, put it in Park, foot off brake and check air temp) then there's a short somewhere that is interfering with proper A/C operation...in other words, your compressor is failing to operate.
3. I assume, since you are slowing down or at a standstill, your RPM's have dropped compared to when you are moving and the A/C works OK. When was the last time you checked or replaced your accessory drive belt?
Old 09-29-2011, 05:32 PM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
our ford escape used to have the ac turn warm when you stopped. turned out it was low on r-134 . they charged the system and its been fine since
Old 09-29-2011, 05:33 PM
Good suggestion ^^^^ so that means a level and pressure check would be a good thing to do.
Old 09-29-2011, 05:37 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
It may be a good idea to have a shop put some dye in it so they can check for leaks.
Old 09-30-2011, 09:23 AM
Default A/C turns hot when braking (cont'd)
It doesnt get hotter gradually when I slow down. If I have the A/C on it blows cold air awesome, but when i slow down to stop at a stop sign or red light I here a kind of "POP" noise from under the glovebox and the A/C instantly goes hot air. Also happens in vent mode too. I have to turn the A/C off and the blower to low setting, then turn it back on after driving about 50 feet. If I turn it back on instantly its still hot. The only thing that I have noticed is that is "pump" the brakes as I slow down the A/C will sometimes stay cold. LOL...thankfully winter is coming up - no problems with the heater.
Old 09-30-2011, 12:03 PM
rfking rfking is offline
Vehicle: 2001 Dodge Ram Quad Cab
rfking is on a distinguished road
I've not been into a dodge dash before so I'm not sure. Isn't there a vent or door that is operated by vacuum. The brake booster pulls vacuum and you could be losing the vacuum to the climate controls. Try what MADDOG said.
Old 11-03-2013, 03:21 PM
needlotshelp needlotshelp is offline
Vehicle: 2001 dodge ram
Color: silver
needlotshelp is on a distinguished road
I have a problem with a/c going to heat when stopping. Can anybody help me fix this? It gets very hot when this happens. It makes a pop sound then heat.
Binding on turns ? mlowney Suspension 9 05-24-2015 08:15 AM
Engine Braking... SvB4EvA 2010 Dodge Ram Forum 16 09-30-2010 09:04 PM
Braking is lighting up front parking light?! iRESQu Electrical 12 09-01-2010 07:58 AM
Engine Turns Over For Too Long ramalamadingdong 5.9L V8 Specific Topics 8 08-06-2010 08:18 AM
Shaking while braking rnhansen Suspension 12 12-11-2009 10:23 AM
