Old 09-29-2011, 05:58 PM
Nagel86's Avatar
Nagel86 Nagel86 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: R/T
Rep:13
Nagel86 is on a distinguished road
Default Taking off the stock shifter?
I just got my new shift knob from custombilletstore.com, and i was wondering how you remove the stock shifter. I didn't want to try to remove it until someone that has done it chimes in.
Old 09-29-2011, 06:03 PM
Good question! Most of the MOPAR shifters I have seen are "lefty loosey, righty tighty" and just twist off. They do have a bit of thread locker on them so it does take quite the twist to get them off.
Others have a small release detent or clip at the base of the handle, usually on the front side of the shaft. You push the detent or clip in and twist or twist and lift.
Old 09-29-2011, 06:07 PM
Nagel86's Avatar
Trim Level: R/T
Rep:13
Thanks for the quick reply. I was going to try twisting it off, but i don't want to break it if that's not how you take it off. I'll look for that release clip you were talking about first.
Old 09-29-2011, 06:08 PM
HaydenWar's Avatar
HaydenWar HaydenWar is offline
Vehicle: 2010
Rep:45
HaydenWar is on a distinguished road
Twist the chrome piece at the bottom and it will twist off, pull up on the shifter. Do not have your face above it when you do so, everyone will laugh at your busted lip.
Old 09-29-2011, 06:19 PM
Nagel86's Avatar
Trim Level: R/T
Rep:13
lol thanks for the directions and the tip. Probably saved me a black eye.
Old 09-29-2011, 06:21 PM
LOL....that's good advice right there
Old 09-29-2011, 06:23 PM
Nagel86's Avatar
Trim Level: R/T
Rep:13
How hard do you have to twist the chrome piece? I tried but it didn't want to budge.
Old 09-29-2011, 06:26 PM
HaydenWar's Avatar
Vehicle: 2010
Rep:45
I hardly had to twist mine at all
Old 09-29-2011, 06:35 PM
Nagel86's Avatar
Trim Level: R/T
Rep:13
Ok i got it installed, looks awesome. Thanks for the help guys.
Old 10-03-2011, 12:27 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
You dont twist it you just insert a flat head between the shifter and chrome piece pry down and it slides right off then the handle just pulls right off after the chrome piece the handle is just sitting on it.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
2010 1500 5.7L Single to Dual Exhaust plus Intake??? NewfieRam1500 Exhaust 26 04-07-2014 12:45 PM
Stock Rim/Tire width question NCBowhunter Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 10-11-2010 01:08 AM
Anyone with stock Alpine, Swap to Quality Spekaers but Retain the Amp? RammD Custom Dodge Ram Interior Modifications - Custom Audio / Video 22 08-12-2010 08:45 AM
