Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-30-2011, 10:55 AM
camino12 camino12 is offline
camino12 is on a distinguished road
Default Rear Diff. Gear Oil on 2009 Dodge Ram
Hi Folks,
I own a 2009 Dodge Ram, Hemi 5.7, 2X4, Laramie.
I changed the rear diff oil at 15000 miles. I used the following:
Valvoline
Synpower full synthetic
75W-140
Today when I took my truck for free engine oil change, the guy also checked the gear oil and noted on his log that the "fluid oil looks wrong."
I told the guy this is Valvoline synpower full synthetic 75W-140.
He said we use Mopar full synthetic with "friction modifier."
Do you agree with the dealership?
Old 09-30-2011, 11:21 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Originally Posted by camino12 View Post
Hi Folks,
Valvoline
75W-140
Either one works, but if you did not put friction modifier in there, be sure to do so NOW, before your rear end is spilling its fluid all over the interstate. The friction modifier can be purchased in a small bottle from your dealer parts dept, and added to your current fluid. I would do this NOW, ASAP...before your diff eat's $hit.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 09-30-2011, 12:42 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Do you have limited slip differential? I think the friction modifier is only required with LSD.
How many miles do you now have?
Sean
Old 09-30-2011, 01:59 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
He has an LSD. 09 Laramie= fully loaded=LSD.
US ARMY-RETIRED
Old 09-30-2011, 02:50 PM
Rep:2657
If you do have the Limited Slip Differential
then you would need the Friction Modifier
I'm curious as to why you changed the fluid so early
My service writer kept telling me that mine was due for service at about 15,000 miles also, he said that the technician said it was dirty.
I waited until 30,000 miles & changed it, i went to Royal Purple & an aftermarket cover.
The funny thing is, the service writer still tells me that i am due for service, makes me wonder if the tech ever checks the fluid level
Old 09-30-2011, 02:52 PM
snrusnak's Avatar
Rep:1385
Doesn't the manual call for it at 15k or 25k miles? or somewhere around there...
Sean
Old 09-30-2011, 06:03 PM
Quick update:
According to my truck build sheet, I have conventional diff. NO LSD. I just confirmed that with two dealerships after I gave them the VIN number.
The dealer that changed my regular oil doesn't know squat. If he would have entered my VIN he would have known that mine doesn't have an LSD. No LSD means no friction modifier.
Old 09-30-2011, 10:47 PM
snrusnak's Avatar
Rep:1385
^ yeah you should be fine then...(I think...lol)
Sean
Old 10-01-2011, 10:20 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Manual says 18K Check and replace if neccassary.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 10-03-2011, 07:02 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
Are you using your truck; 1)police, 2)taxi, 3)fleet, 4)off-road, 5)frequent trailer towing?
If not, my 09 Owners Manual ONLY requires to inspect fluid. Up to 144,000 Miles or 144 Months it does not require changing.
I have the factory Lifetime Power Train Warranty, If they want it changed, it's on thier dime! My dealer tried to sell me the 15,000 mile change, I told them if Dodge thinks it needs changed, Dodge can pay. They said "it will be OK, no need to change".
I don't need to spend extra money just to say I have XYZ fluid and I change it every XXXX miles. If it needs it, do it, if not, why?
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Chrysler Group LLC Reports July 2010 U.S. Sales Increased 5% UN4GTBL Automotive Industry News and Dodge Press Releases 1 08-04-2010 02:28 PM
Rear Diff fluid ?? trainplanemech Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 04-03-2010 09:29 AM
2009 December - Dodge Ram Member Of The Month BlueJet 2009 Dodge Ram - MOTM - Archives 20 01-07-2010 03:35 PM
05 1500 Rear Diff Bearings AaronF Suspension 1 08-25-2009 12:58 AM
Rear end gear swap?? ScatPackRam Dodge Ram General Discussion 6 08-04-2009 07:08 PM
