the 5.9 freebie mods.. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Old 09-30-2011, 02:10 PM
mikeismadness's Avatar
mikeismadness mikeismadness is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: Laramie SLT
Color: emerald green
mikeismadness is on a distinguished road
Default the 5.9 freebie mods..
alright so for some of us newbies and others with questions id like to start a thread about freebie mods or adjustments that can potentially give us more power and MPGs.
Old 09-30-2011, 03:02 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Default Crank sensor mod.
Originally posted by KRC Performance:
Remove the crankshaft sensor on the aft/passenger side of the block. It is held down by (2) 1/2" bolts and pulls out of the tranny bell housing when loose. There is a rubber grommet in the bell housing also, remove it. Now look at the sensor's bracket, notice the 2 bolt holes. Slot each hole 3/8" both ways, still giving the bolts something to hold onto. Then insert the sensor back into the bell housing, making sure you pulled out the rubber grommet. Thread the 2 bolts back in loose, then slide the sensor as far as it can, towards the oil filter, away from the intake. This will advance, moving it towards the intake in the same direction of crank rotation and will retard the base timing; do not do this unless your teenager is driving the truck. It will usually be limited by the bell housing how far you can move it. If you are really brave, grind the bell housing and fab a new adjustable bracket. This will add 3-4 degrees of timing across the whole board of advance tables, and cure the Death Flash problem in your Magnum. That'll be $5 please...just kidding!
Old 09-30-2011, 08:40 PM
nice post! so basically your advancing/retarding your timing?
Old 09-30-2011, 08:46 PM
would you feel a performance gain with the butt dyno? or a mpg gain?
Old 09-30-2011, 09:39 PM
Rep:99
Definitely butt dyno. If you're doing a lot of stop-n-go, would probably help mpg a little. Adding an extra 3 to 4 degrees to your base ignition timing is a time-honored deal (definitely perks up the low-end response) that was accomplished by giving the distributor a good twist. However, they took that away with the Magnum. This mod makes it possible again. Not as good as the distributor twist, but 4 degrees is better than nothing. The LA/Magnum family of engines likes 32-34 degrees total advance for best power. I don't have the specs, but some things never really change, and the factory settings going waaaaay back usually had max advance of around 26-28 degrees. It's all computerized now, but I'd bet the numbers are close. By adding 4 degrees, you get closer to ideal max for this family of engines, and since it's all in the initial timing, it also directly boosts low end grunt.
Keep in mind that increased ignition timing can and will require higher octane gas in some instances. Depends. Might not, unless you're pulling a trailer, or on really hot days. Good thing is, it's easily reversed if you want.
Old 10-01-2011, 12:29 PM
definitely a good start to the thread. thanks! id give ya rep points but my phone wont let me
Old 10-01-2011, 12:35 PM
and u said "slot each of the wholes 3/8" what exactly do u mean? with washers? drill it out?
Old 10-01-2011, 01:16 PM
Rep:99
With the 5.9 compression ratio, you're less likely to ping than with the 5.2, but most will opt for the timing boost and counter any minor ping by swapping in a 180 degree thermostat.
On slotting, you can use a drill, dremel, or even a good rat tail file. You're basically elongating the holes into bolt-width slots.
Old 10-01-2011, 04:09 PM
sweet! sounds like a great mod
Old 10-02-2011, 12:19 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
should work with the 5.2 right?
Recycle Your Mods! wolfman10 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 9 04-09-2014 08:07 PM
Multiple Mods Complete RamMan27 Dodge Ram Pictures - Photos 14 08-18-2011 08:06 PM
Lots of mods! (pic heavy) caseykerner Dodge Ram Pictures - Photos 15 08-16-2011 12:38 PM
Recent Mods Indeepcamo LD RAM - General Discussion 12 05-12-2010 02:50 PM
Mods + Pics of a RAM in Germany Nordlicht 2009 Dodge Ram Forum 10 02-24-2010 09:05 AM
