Old 09-30-2011, 06:09 PM
SMOKINGRT SMOKINGRT is offline
Vehicle: 2011 dodge ram
Trim Level: rt
Color: grey
SMOKINGRT is on a distinguished road
Default looking to debadge
trying to debadge my new RT... any tips or advice on how i can do it myself with out messing it up???
Old 09-30-2011, 06:59 PM
07yt1500thunderroad's Avatar
07yt1500thunderroad 07yt1500thunderroad is offline
Vehicle: 2012 passat tdi se w sunroof
Rep:70
07yt1500thunderroad will become famous soon enough
a plastice caulk remover tool. goo gone or a very mild paint thinner. be sure to have soap and water handy and you should be good.
Old 09-30-2011, 08:54 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
My debadge thread is below. Might help, might not. Just wanted to pass it along.
http://www.ramforumz.com/showthread.php?t=86530
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 10-01-2011, 12:06 AM
rottekatz rottekatz is offline
Vehicle: 2011 Ram 1500, QC
Color: Cherry Red
rottekatz is on a distinguished road
I did mine. Parked in sun for about 20 minutes, used nylon fishing line (with a sawing motion at a low angle) to remove the plastic numbers and letters, peeled the foam adhesive off by hand (pretty easy), polished (with car liquid polish), then waxed. Took about 20-30 minutes for both sides.
I had purchased the 3M adhesive remover wheel and had it on hand, but the adhesive peeled off so easy that I didn't use the wheel and sold it on ebay new.
Old 10-01-2011, 12:27 AM
Mudder's Avatar
Mudder Mudder is offline
Vehicle: 2012 Jeep Wrangler
Trim Level: Unlimited Sport
Rep:40
Mudder is on a distinguished road
Did mine today. Fishing line, hair dryer, turtle wax adhesive remover (best I've ever used), and some time. Was a pain in this 75 degree weather until I busted out the hair dryer.
Old 10-01-2011, 12:59 AM
I used some 3M Adhesive Remover spray, a plastic spackling tool and a bit more adhesive remover after the parts came off to clean up the rest of the leftover adhesive.
Old 10-01-2011, 01:24 AM
Mudder's Avatar
Rep:40
You guys have got bigger cajones than me. No flippin way id use a plastic or otherwise tool to scrape it off. One slip and ouch. Or perhaps I just have poor fine motor skills...
Old 10-01-2011, 07:57 PM
NeverEnuff NeverEnuff is offline
Vehicle: 2014 Ram
Rep:87
NeverEnuff will become famous soon enough
I used the hair dryer & fishing line method. Still a lot of work to get sticky stuff off. I used Goo Gone and WD40 and the washed and waxed area. I would like to remove the huge Ram logo on the tailgate. Are there holes behind the emblem? On my Ford I had a body shop fill the holes and repaint the tail gate. It gave it a real clean look.
Old 10-02-2011, 12:36 AM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Color: Grey
Rep:27
stangd1909 is on a distinguished road
Your truck looks good mudder! Did the hair dryer help a lot?
Old 10-02-2011, 12:57 AM
Mudder's Avatar
Rep:40
Big time. It was around 75 or so and the badges came off easy with the 50 lb test line, but the leftover foam tape was stuck on there buddy. I did the passenger side without it. Then I wised up and used it on the rest. Once you heat them up a bit the tape gets nice and pliable and comes off pretty easy.
After I had it off, I hit the residue with that turtle wax adhesive remover (available at you local walmart) and then rinsed it off and rewaxed those areas. And because I'm paranoid I then ran it through a touch less wash real quick to get any of the adhesive remover that had run off of it.
Debadge or not? Second Life Dodge Ram Forum Polls! 88 03-23-2015 03:12 PM
Should I Debadge My Truck? DeputyNelson Dodge Ram Forum Polls! 54 12-04-2014 09:36 AM
Another Debadge Thread Stump3r Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 1 08-19-2011 08:23 PM
Next Mod....Debadge RedDodge 2011 Dodge Ram Forum 9 05-31-2011 03:45 PM
RAM Debadge pics TRIPOD Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 15 06-15-2010 09:58 PM
