Old 09-30-2011, 08:11 PM
Dortmunder Dortmunder is offline
Vehicle: 2011 RAM 1500 Sport Quad Cab
Color: Grey
Rep:31
Dortmunder is on a distinguished road
Default Remote Start and Fan/Heat Control
Hey all.
I'm curious about my Remote Start and the fan controls. No matter what I have them set to, they seem to be going full blast until I put the key in and set the ignition to on.
I want to know if it's possible to customize that somehow. It's going to be winter soon and it gets pretty cold here(-15-45c most of the winter). I don't want to fire up the truck to warm up and have it go full blast defrost onto the window and likely crack it.
I've seen this happen before. The defrost heats up the window too fast and it cracks. Like dropping an ice cube into hot water etc.
Old 09-30-2011, 08:18 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
With the sport and the remote start option it has a convenience setting that will turn on the heated seats, heated steering wheel and turn on the heat or air conditioning. This can be turned off in the EVIC. Read through your owners manual and it will explain how to turn this option on or off. With it off you can do it the old fashioned way of setting your heating controls prior to exiting the vehicle.
Big Red my old 2011 Sport
Old 09-30-2011, 08:55 PM
Color: Grey
Rep:31
Yeah, I noticed the seats and steering wheel heaters on a couple of days ago. Only seems to do it when it's 5c or lower, around that temp anyways.
So if I turn that off they won't come on until I manually do it? Or can I have it both ways sort of. Have the seats/wheel heaters come on, and have fan controls manually set too?
Old 10-01-2011, 12:55 AM
Stump3r's Avatar
Rep:1266
Not 100% sure, try it I just leave mine with it turned on. I'd imagine if you set the heater controls manually it would just run with what you have set unless the computer over rides everything? Give it a shot and see what it does. I might have to go play with mine just to see what it will do.
Old 10-01-2011, 02:26 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The 'Remote Start Comfort System' (Enabled/Disabled in the EVIC under 'System Setup') will -
In cold weather - Turn on the driver heated seat and heated steering wheel for the duration of the remote start cycle
In hot weather - Turn on the driver ventilated seat for the duration of the remote start cycle
If you have your heater/AC controls in the 'auto' position, during the remote start cycle, it will attempt to achieve the temperature setting you have selected. In the cold, it will set the fan high and on defrost in an attempt to have the windows clear for you. As the vehicle is likely cold when this feature is used, it's blowing cold air to start, and slowly warming as the engine temp increases. This will not cause any windshield issues, as the beginning temp is the same temp as the windshield anyway. Actually, it's a lot less likely to cause an issue then warming the vehicle, then cranking on the defrost after the engine temp in up.
brad
Interested in one of my mods?
