Old 09-30-2011, 09:11 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Default 2010 Ram 1500 no start help
my ram 1500 will not start. i pulled it up 50' and went in the house. and now it will not start. last time it started it turned on the abs/esp lights and abs on the left side of the cluster. i then switched it off and when i tried to start it back up it would not start. it is still flashing those lights and now the little red light near the gas gauge is flashing.
what the hell is going on with this truck??
i just had it in the shop yesterday bc the brakes failed YET AGAIN and the parking brake cable snapped.
what is the deal here???
i get the feeling im paying too much money for a yard gnome.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 09-30-2011, 09:27 PM
03mgmcobra 03mgmcobra is offline
Vehicle: 2010 dodge ram 1500 sport
Color: Brilliant black
03mgmcobra is on a distinguished road
Subscribing. Interested
Old 09-30-2011, 11:48 PM
Outlaw's Avatar
Color: Bright white
Rep:435
No idea whats up guys???
[/CENTER]
Old 10-01-2011, 12:06 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I had this happen once on my 04 Ram, and once on my 08 Ram. Both times in the same location. In my case, it was the anti-theft system that wasn't happy. I removed the battery cable, reconnected it and drove away. I have yet to have this happen with my 2010, but I do have a 10mm wrench in the console for 'When' it does happen.
brad
Interested in one of my mods?
Old 10-01-2011, 02:29 AM
Outlaw's Avatar
Color: Bright white
Rep:435
i tried disconnecting/reconnecting the battery.
no dice
[/CENTER]
Old 10-01-2011, 02:36 AM
brad12kx's Avatar
Rep:2581
Do you have another key to try? I'm just wondering if something happened and it's dis-allowing that key.
Thinking out loud -
WIN module
PCM (Would explain both this and phantom reoccurring brake issue)
.... You have really had bad luck with your truck!
brad
Old 10-01-2011, 02:50 AM
Outlaw's Avatar
Color: Bright white
Rep:435
well at first it just would not turn over. all the idiot lights/accesories would work. that doesnt happen with a disallowed key.
now it wont even read the key. no start, no accessories, no nothing. i just need to get rid of it and get a f word truck
[/CENTER]
Old 10-01-2011, 03:04 AM
brad12kx's Avatar
Rep:2581
They have problems too.....but you seem to have more than your fair share.
When you disconnected the battery, did you take the disconnected cable and touch it to the other cable for a brief moment? That speeds up the discharge cycle from 30 minutes to 1 second.
Then pull fuse J15 (60A) before re-connecting the battery.
Re-connect battery
Install J15
This procedure will eliminate any issues that can be caused by intermittents during the battery re-connect.
.... I think you have PCM issue that has been plaguing your truck. As bad as this sounds, maybe this is a good thing. It it's good and dead, then maybe, just maybe, your dealer can finally get this sorted out once and for all.
brad
Old 10-01-2011, 03:10 AM
Outlaw's Avatar
Color: Bright white
Rep:435
how could pcm issues cause total brake failure??
i can see that for keys but not brakes and driveshafts
[/CENTER]
Old 10-01-2011, 03:22 AM
brad12kx's Avatar
Rep:2581
The ABS system is controlled in part by the PCM....and that's where the 'main' program for the truck is run from. Since we no longer have direct control over our vehicles (electronic throttle, ABS, etc), if the computer program gets bad info, or the operating system gets messed up, or an internal malfunction in the computer manifests, it can have the strangest consequences in the strangest things.
I've followed your brake issue, and am so glad I don't have this...that would scare the pooh right outta me, and would take a long time before I every trusted the truck again.
brad
2010 Ram 1500 Sport 4x2 Fury Dodge Ram For Sale - Used Dodge Trucks 7 07-13-2011 09:14 PM
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
2010 Ram 1500 rims on my 2002 Ram 1500? shaded02 Dodge Ram General Discussion 3 05-05-2011 09:21 AM
Will Dodge Ram 1500 2010 Wheels and Tires fit a 1998 Dodge Ram 1500? koalatyman Dodge Ram Wheels And Tires 1 04-14-2011 10:38 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 09:27 PM
