Old 09-30-2011, 10:21 PM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
Default tire pressure monitor
I checked tire pressure as set by my local Dodge dealership and the displays shows 37 PSI. I realize it's over the 35 psi it should be at so I checked with tire gauge and it shows 35 psi on all tires. Which one should I rely on?
why are they not the same?
Old 09-30-2011, 10:57 PM
unrealtrip's Avatar
unrealtrip unrealtrip is offline
Vehicle: 2008 Ram Big Horn 4x4
Rep:27
unrealtrip is on a distinguished road
What kind of tire gauge are you using? That makes a pretty big difference.
I've got a shotgun a rifle and a four wheel drive...
Old 10-01-2011, 02:29 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
In the wonderful world of tire pressure, 35 and 37 are basically the same.
The TPMS is not touted as being 100% accurate, but I have found mine to be very accurate as compared to a calibrated tire pressure gauge.
Since I own a few tire gauges (a few too many), I have checked them all against my calibrated one, and marked the 'error' on them so when I do use them, and can 'correct' the reading. Some of them are out by as much as 5psi at 40psi .
Strangely enough, the most accurate 'off the shelf' units I have, are those stupid cheap digital talking units from Canadian Tire. I have 5 of them, and they all are within 1/2 psi from my calibrated one....go figure.
I say "Trust the EVIC" in general, and don't worry at 2psi....it won't make a spit of difference......but I'm not a tire expert, so take it for what it's worth.
brad
Interested in one of my mods?
psi, tire, tire pressure
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 09:47 PM
tire pressure monitor system problem texaskid 2010 Dodge Ram Forum 9 09-30-2011 03:16 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 05:29 AM
TPMS Tire Pressure Monitor Light 2010 351 Stang 2010 Dodge Ram Forum 6 08-28-2010 01:59 PM
Tire pressure monitor 2010Ramowner 2010 Dodge Ram Forum 3 04-30-2010 01:41 PM
