Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 10-05-2011, 04:34 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
It has something like 54,xxx right now. Code was cleared when car was fixed, this pop up was a new one entirely. Cleared itself just as fast as well. Was the same p0300 as before.
Sure it'll suck, but it'll make you a man
Old 10-05-2011, 09:24 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Hold on....you said the timing belt broke right? So does that mean you had a new engine installed? If so, they would have had to do a crankshaft sensor variation relearn procedure...and I've heard only the dealer can perform this correctly(~$60). I've read many cases where an engine was swapped in and ran perfect but the light came on and after having this done it was fine. You did say you replaced the engine, yes? And it runs fine right, there's not an actual misfire, just a code?
Sean
Old 10-05-2011, 09:27 AM
snrusnak's Avatar
Rep:1385
Other causes could be: valve not fully seating, O2 sensor, clogged CAT, Coil, plugs, wires, ECM, crankshaft sensor, camshaft sensor, vacuum leak...
Most likely if it runs fine and you swapped engines it needs the relearn.
Sean
multiple misfire at idle and under acceleration nick2889 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 10 08-18-2011 12:25 PM
Misfire following a tranny rebuild SCUBA Sam 5.9L V8 Specific Topics 1 06-29-2011 07:29 PM
Cylinder 5 misfire, and now cylinder 8 and a random misfire... suggestions? itsaRAMthing 5.9L V8 Specific Topics 5 06-05-2011 08:35 AM
Help!Random Misfire 03BlueRam 3.7L PowerTech V6 Specific Topics 3 12-30-2010 06:43 PM
Random Misfire and Cyl 8 Misfire jabyrum 2009 Dodge Ram Forum 11 08-20-2010 06:39 PM
