Old 10-01-2011, 02:00 PM
darkmoon1024 darkmoon1024 is offline
Vehicle: 1995 dodge ram 2500 4x4
Color: black and silver
darkmoon1024 is on a distinguished road
Default 5.9l magnum not the timing chain?
I have a 1995 ram 2500 with a 5.9 magnum, it died and gave the signals of busting the timing chain. Upon removing all the crap and opening the cover i found the timing chain intack and in great shape ( 145000 miles) which I am now dumb founded . Does anyone have any idea of what my problem is. Thank you for your help.
Old 10-01-2011, 09:09 PM
mattee's Avatar
mattee mattee is offline
Vehicle: 2002 1500 Ram QC 4x4
Rep:13
mattee is on a distinguished road
we need more info. what exactly happened when it died. Did the engine light come on? If so do you know what the code or codes are. Any more info you could give will help.
Old 10-02-2011, 12:09 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Why did you think it was the timing chain?
What were the symptoms?
What troubleshooting steps have you taken so far?
brad
Interested in one of my mods?
Old 10-06-2011, 08:34 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
Need more info!
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 10-07-2011, 09:24 PM
Default found out some of the problem i am still stumped
Well I have some of the problems, the spark was weak so i put on new wires,cap ,rotor, and coil. The egr vaccum thing is totally melted(must be egr is stuck open?) i am trying to get one locally I unplugged the connector and the truck runs some times then all of a sudden it just dies out let it sit and it may or may not start again but when it runs it runs like a champ as if nothing were ever wrong could the egr being unplugged cause it to do this? or is there some other problem. the spark is good, got fuel to rail not sure the pressure but it squirts out good, and compression on all cylinders look good
Old 10-12-2011, 11:58 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Stick a fuel presure gauge under the wiper and plug it into the fuel rail, and watch the gauge when the motor is being a bad actor. Any varience in the psi means a pump change. having fuel present at the fuel rail under pressure is not the same as having the correct, steady pressure at the fuel rail.
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 12:06 PM
Secondary Timing Chain Holder Tool Erickson 4.7L PowerTech V8 Specific Topics 2 09-09-2011 09:08 PM
timing chain replacement 2kram 5.9L V8 Specific Topics 2 07-04-2011 05:25 PM
Timing Chain Slack 4.7L kevinph 4.7L PowerTech V8 Specific Topics 24 03-19-2011 08:44 PM
Any mtc required for timing chain? Turbovsix 2010 Dodge Ram Forum 6 09-09-2010 12:43 PM
