Old 10-01-2011, 03:18 PM
jtodt jtodt is offline
Vehicle: 2011 Dodge Ram 1500
Rep:38
jtodt is on a distinguished road
Default Modified factory Y-pipe
I had a thread going the other day about the factory Y-pipe and if anyone had tried to modify it. Well, today I dropped my exhaust off the manifolds and modified mine. I used a plasma torch, oxy acetylene torch, and a mig welder. First I cut out the restriction with the plasma and the gas torch. Then i heated up the pipe to widen out some off the restriction before the y. I used the torch to heat up the pipe to bring the two pipes together and then welded the pipe back together.
After I reinstalled the exhaust I noticed the difference right away. The throttle was more responsive and the tone of the exhaust even changed a little bit. I am not one to waste gas or rubber, but my truck would not break the tires loose from a stop before and now it will.
I had no idea that the factory exhaust was really that restrictive, WOW.
Cost of modification - $0
I have some pics but the site won't let me post them. I guess the files are too large.
Old 10-01-2011, 03:37 PM
Rep:38
Here are the pics. Figured out a way to compress the files.
Old 11-05-2011, 11:49 PM
CSG CSG is offline
Vehicle: 2011 Ram Sport 4x4
Trim Level: Sport 4x4 crew cab
CSG is on a distinguished road
Default Factory Warranty
Happy that you are seeing such a difference. You need to be careful going forward as if the dealer discovers this it could potentially void your warranty. I had this conversation with the Mufflex folks today and they do not recommend that new vehicles change this out. Just giving you a heads up.
Old 11-06-2011, 08:37 PM
Rep:38
Thanks for your concern. What was mufflex's reasoning for not doing the y-pipe mod? There are countless members on this site that have done a y-pipe mod. Most all have noticed an improvement in the performance of their truck. As for the warranty, it would be a void of the exhaust warranty. And if you do it the way I did, it still looks factory.
Old 11-06-2011, 09:32 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I have a Y-pipe and mine and have been told everything after the cats is fair game for mods!
Old 11-06-2011, 11:50 PM
riggz riggz is offline
riggz is on a distinguished road
The only thing they could deny warranty work on would be the exhaust components. They wouldn't be able to deny a warranty claim if your radio stopped working or your motor blew up.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
replaced my factory y pipe today Keiser Blade Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 05-27-2013 02:18 PM
Installing Factory Brake Controller brc3858 2010 Dodge Ram Forum 17 05-07-2013 08:02 PM
x pipe and y pipe together? homerkill Exhaust 5 07-29-2011 05:38 PM
2010 ram hemi hp# 440 modded, x pipe or h ? SPEEDFREAK Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 24 07-08-2010 11:34 AM
