ZDOG
Old 10-01-2011, 03:43 PM
cyberpine cyberpine is offline
Vehicle: 2012 Ram Hemi regular cab
Rep:53
cyberpine will become famous soon enough
Default 305/60/18 with 18x9 +0mm offset
According to West Ky Customs this combination does not rub on a stock 2wd 4th Gen Dodge Ram. Thoughts? Anybody know of anybody with this combo or have a pic they can share?
http://www.westkycustoms.com/product...018-Tires.html
This tire is 1/2 inch shorter and 1.25 inches wider than stock 275/60/20. Offset is is 3/4 of an inch further out so will look much more aggressive thanks to width and stance.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 10-06-2011, 09:34 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi wish I had an answer for you; best I can do is to this for you!
Old 10-06-2011, 10:05 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Not close to your answer or truck profile but i am running 305 width tire on 18x9 +18mm with no rubbing issues buuuuuuuuuuuuuuuuuuuuut its only at the rear.
18x9 offset sweet spot for 305/60/18? cyberpine Dodge Ram Wheels And Tires 7 04-19-2013 04:31 PM
18x9 -12mm offset with 33x12.5 tires on 4th Gen 2wd stock Dodge Ram 2009+ cyberpine Dodge Ram Wheels And Tires 1 09-28-2011 11:58 PM
Vintage negative offset type rims cyberpine 2010 Dodge Ram Forum 2 04-06-2011 10:36 AM
What width tire can I fit for an 08 with a 17x9 0mm offset? 345cube Dodge Ram Wheels And Tires 2 04-05-2011 01:14 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 03:28 AM
