Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 10-01-2011, 06:02 PM
0520 0520 is offline
Vehicle: 2009 Dodge Ram 1500 4x4
Trim Level: laramie
0520 is on a distinguished road
Default 2009 4x4 hemi CEL on
check engine light was on in my 2009 truck. I took my truck to the dealership and they said code was P1004 and replaced intake short runner and also stud, wiring etc. This all happened around 36000 miles at the end of factory warrenty. I also noticed the FUEL SAVER light started working this never worked before. Well everything worked fine for around 2000 miles then CEL comes on again the FUEL SAVER light quits working again, and When you start the truck with remote it will run for a few seconds then shut off. I took the truck back to the dealer as soon as this happened thinking this was same problem as before. They checked for codes and said the code was showing a missfire on one of the cylinders and the problem was sparkplugs needed replaced and fuel system needed cleaned/flushed. Cost around $500.00 I find this hard to believe with only 38000 miles and truck seems to run fine. Ive never felt a miss at all. Anyone else with similar problems.
Old 10-01-2011, 06:05 PM
Welcome to the forum.
This sounds a bit premature for plugs, however, since you had the prior problem the plugs may have given up a bit early.
You can do this maintenance yourself and save some bucks. You need plugs (stick with the stock ones) and you can clean your own fuel system with an in-tank cleaner and some cleaning of your throttle body.
Then, get a catch can and install it. This will significantly reduce the amount of oil that goes back into your intake from the PCV system.
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 09:30 AM
new from romeo,michigan 2009 1500 Hemi mestude Newbie Checkin! 17 01-02-2011 11:55 AM
What to pay 2009 Ram Hemi? ronnievanauken 2009 Dodge Ram Forum 21 04-17-2010 04:13 PM
Headers for the 2009 Hemi 4WD Quad Cab? doublej Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 09-04-2009 04:00 PM
What octane for the 5.7 hemi 2009 superdodge33 Dodge Ram General Discussion 4 02-23-2009 09:58 PM
