Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 10-01-2011, 10:07 PM
DirtyD's Avatar
DirtyD DirtyD is offline
Vehicle: 03 2500
Color: Gray
Rep:45
DirtyD is on a distinguished road
Default Yet another exhaust question...
Like everyone else, I want my truck to sound like a truck. My friend has a 02 dodge just like mine "just a lot bigger" and I love the way it sounds, but he doesn't have a muffler, just cats, then it goes to a Y pipe "for dual's out"... my question is... with out a muffler isn't there a lack in back pressure?
03 2500 ( Hemi ), 6" lift and 38" Toyo Open Country M/T
Old 10-01-2011, 10:17 PM
Yes, you do lose some backpressure and low end torque with that arrangement. It flows great at upper RPM's though.
Old 10-02-2011, 09:26 AM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
how much low end torque? will i notice it when towing?
Old 10-02-2011, 09:34 AM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
I don't have the numbers, but I do feel that you will feel it while towing as you want the low end torque...but if its light loads (few hundred pounds) you might not notice it
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 10-02-2011, 09:58 AM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
You will notice the difference. I notice the difference when I have a closed cutout versus having the cutout open.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 10-02-2011, 10:55 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
ok thanks yall.
Old 10-03-2011, 12:38 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Sounds like you're all set but just wanted to add that losing back pressure will not hurt anything, so proceed without worry ....you won't lose low end due to less back pressure. It's a common "myth" that just about everybody out there believes.
Sean
Old 10-03-2011, 01:40 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
so i wont lose the torque i need?
Old 10-03-2011, 01:45 PM
snrusnak's Avatar
Rep:1385
If you keep the same diameter exhaust pipe, and remove the muffler, you will only gain torque and hp at any rpm.
The reason people sometimes lose low end torque is because they change to a large diameter exhaust piping, and this slows down the exhaust gas velocity....and high exhaust gas velocity helps scavenging, and helps "suck" the exhaust out of the engine, so there is a balance in exhaust pipe diameter for best low end and top end performance. Stick with the stock exhaust size and you'll be fine, even if it was all straight through from the engine to the tailpipe...
Sean
Old 10-03-2011, 02:08 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
well the exhaust shop just told me it would cost 300 for that set up. is that a good deal?
Exhaust question? Ram2011sport 2011 Dodge Ram Forum 40 07-27-2011 07:07 AM
Question about exhaust Twjones87 Exhaust 9 05-17-2011 04:05 PM
New to the site with an exhaust question atlkozmo2003 Newbie Checkin! 11 05-04-2011 11:45 AM
question about exhaust resonator mark1963 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 9 04-02-2011 07:02 PM
Exhaust Question white06ram Exhaust 9 01-15-2011 07:11 PM
