Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-02-2011, 11:03 AM
02ramsport's Avatar
02ramsport 02ramsport is offline
Vehicle: 2002 Dodge Ram1500
02ramsport is on a distinguished road
Default truck drives like a boat
I have a 2002 ram sport 4x4 and it has started driving like a boat at low speed. when i get to highway speeds it wonders all over the place and a slight wind from a passing car makes it worse. on the freeway i have to follow behind a semi to keep it in one lane. i recently replaced the ball joints shocks and upper arm bushings and got an alignment. but it did not solve the problem. any ideas would help.
Old 10-02-2011, 11:21 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
this usually happens when rear is too heavily loaded(front end rides high) this might be long shot but if rear breaks are dragging can cause somewhat of that effect.im probly way off but easy to check that.
Old 10-02-2011, 11:26 AM
02ramsport's Avatar
charlieb thanks but I had the rear end replaced and new brakes installed and the problem does get worse when loaded so I have taken any extra weight out of the truck to include the spare tire and my truck box. it help but only a very little.
could it be the leaf spring bushings in the rear end along with steering components like tie rod ends or rack and pinion going bad? i want to fix it but not spend my paycheck chasing it. thanks for any help or ideas
Old 10-02-2011, 11:48 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Do you have play in the steering wheel? I did and Just fixed mine as it did the same. There is a nut 16mm on top of the steering gear box with a 3/16 allen screw in the center. Loosen the nut and snug the allen screw...depending on how much wear is in the gears it could be 1/2 turn, a full turn or more. snug it and start the truck and wiggle the steering wheel, when all the play is gone you got it, then just tighten the nut back and youre done. I have almost 275K on my truck so I had alot of adjustments to do, Trucker86 is doing his as well.
Mike
Old 10-02-2011, 01:21 PM
charlieb's Avatar
Rep:31
yeah you have to lean toward a front end problem since you have new tie rod and ball joints somehow steering gear(rack and pinion)must have play somewhere lift her up and try to figure where the play is.the steering gear(rack) is easy to replace i did mine in my driveway in 2 hours.rebuilt units are sold as 1 piece and are cheap 200.00 around here in ontario canada.usually when the rack goes it leaks oil (atf+4)if all else fails have a mechanic give an estimate for work needed.still have shops around here that gives free written estimates then decide whether or not to do work yourself.good luck
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 12:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
My truck got hit yesterday. GeauxHunting Dodge Ram General Discussion 41 11-19-2010 01:15 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
