Old 10-02-2011, 05:04 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Default CB/Scanner Install
These 4th gen's don't leave much room for installing electronics, so I finally bit the bullet and did an in-dash install. Not as difficult as I would have thought.
Old 10-02-2011, 06:21 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Very clean install
How deep is that unit and how much space was there to work with? I have been thinking of putting a CB in the same spot. Thanks
Old 10-02-2011, 06:57 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
Originally Posted by highlandchef View Post
Very clean install
Thanks! The scanner measures (according to the manual) 7.06"w x 6.10"d x 2.44"h. There was plenty of room for it, I actually have a serial cable attached to the back of the scanner as well (to update the unit through my laptop) that adds at least 2" to the rear corner on the drivers side.
On my dash I had a spare strip with no switches (it said RAM on the strip); I removed the strip and found that the width was almost exactly what I needed, so I just rough cut the opening small and filed it down by hand to clean it up and to get a nice snug fit with the radio. It uses the same type of bracket a CB does, which mounted to the bottom of the center dash piece; I needed to add a 3/4" block of wood to bring the radio face to nearly level, but once bolted in place it's rock solid. I ran the serial/USB cable through the center console (lots of room there) into the lower storage compartment. For power, I just tapped the accessory circuit that serves the two power receptacles in the console.
I still want to add a VHF radio, I just can't figure out where to put that...
Old 10-02-2011, 07:14 PM
Rep:2616
Nice install,
I have a Ranger 6900F, in my console, also a larger auxiliary fan blowing on the heat sink, i also have a stripped down exterior speaker mounted in the rear curve of the overhead console, its under the roof liner
[IMG]
http://cbworldinformer.com/200111/rci6900ftb_reveiw.htm
Size (W x D x H)
7-7/8" x 9-1/4" x 3-5/8"
Old 10-02-2011, 07:47 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
Nice install,
[IMG]
Size (W x D x H)
Awesome, thanks! I wanted to install the scanner there but it looked like I'd have to cut away the two screws that attach the console piece to the dash. Is that what you did here or are they still there? This might be a great place for the VHF radio.
As an aside, what kind of radio is that? When i was in AZ a lot of guys used VHF but from what I understand they're "line of sight" and won't work well in hilly terrain. I'm looking for something with more range than a CB, but I'm not sure now what is best. Any suggestions?
Old 10-02-2011, 08:22 PM
Rep:2616
There was some cutting, bending, & trimming involved,
the radio is quite large, when compared to the Uniden & Cobras
I have a Uniden PC78XL as a 2nd radio, but i need to make a box for it
I also have to have it TUNED
I also have a Cobra 75 WX ST Compact/Remote Mount CB Radio with SoundTracker® and NOAA Weather, i have it mounted in a suitcase, it is a loaner for anyone on the job that needs one, even the police
[IMG] [IMG]
I also have 2 Midland 40 channel handhelds, for when i need to control traffic
I use the CBs in my work, they are required by law
Old 10-03-2011, 12:02 AM
Rep:220
What do you think of the 75 WX?
I was thinking about that as an option. I need it for keeping track of road conditions, staying awake and in case of emergencies when I'm on the road for work but I don't need it on Long Island, NY between trips. Looked like it would make for a tidy install that would disappear when I didn't need it (less temptation for thieves). I was thinking of pairing it with a Wilson 1000 antenna so that I could remove the whip and just put the cap on it when not needed.
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
Bilstein 5100 install. Pic heavy. 2011 ram 1500 shelby78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 38 11-12-2013 10:37 PM
Air Lift 1000 Install on '11 Sport with 2/4 drop... TerryH Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 18 08-27-2011 11:41 PM
08 Double Din install detailed modified stock bezel ttconvert2001 Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 08-14-2011 10:51 PM
HID Install 09/10 RAMS doz Custom Dodge Ram Interior and Exterior Lighting 14 03-20-2011 02:28 AM
