Old 10-27-2011, 08:57 PM
Hedghawg71's Avatar
Hedghawg71 Hedghawg71 is offline
Vehicle: 2011 Dodge Ram Express
Rep:21
Hedghawg71 is on a distinguished road
Looking good Tony!
Nothing a Hammer can't fix!
Old 10-27-2011, 10:19 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Post
Originally Posted by TonyD87 View Post
Has anyone heard when superchips or any of the other tuners will be available?
I just talked w/ both the Parts & Service Managers @ my dealership this evening and learned a little tidbit of information that leads me to believe that Diablo and Superchips won't ever get the codes cracked! It seems Dodge has added a 'rolling codes' feature to the ECU starting in 2011. This is the same security scheme that your garage door opener uses. After the door opens, the last thing the remote does is generate a new code and send it to the opener so it knows what code to expect the next time. Evidently, the ECU is doing the same thing and generating a new code when you turn off the key. This is why the aftermarket tuner companies are having so much trouble 'cracking the codes' of the 2011's.
It was their opinion that Mopar did this in a effort to reclaim some of the performance parts business and we should soon have an option for a Mopar tuner. When I pressed them for a description (ie: will it look like a Diablo or Superchips?) they said most likely not. It will probably be more of a plug-n-play add-on style that would give noticeable performance increases but not have the 'tunability' of say, a Predator.
So, there's probably something coming but it won't have the flexibility (different octane tunes, performance tunes, economy tunes) that the current programmers have. Kind of a let down but maybe it will be OK. We'll have to wait and see.
Old 10-27-2011, 10:31 PM
Hedghawg71's Avatar
Rep:21
^^^ Well that sucks!
Old 10-27-2011, 10:41 PM
TonyD87's Avatar
TonyD87 TonyD87 is offline
Color: Gray
TonyD87 is on a distinguished road
Well that sucks! I hope they find a way around it because I was waiting to get my exhaust and intake the same time as the tuners came out.
Old 10-27-2011, 10:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If the manufacturer can make a tuner, so can aftermarket companies, it will just take them a long time...
Sean
Old 10-27-2011, 11:09 PM
Barnyard's Avatar
Rep:209
Agreed but it's going to be very expensive. The aftermarket is going to have to incorporate some sort of 'code scanner' to rob the code each key cycle and then feed it back to the ECU. Then they have to modify the program itself. Hopefully the program doesn't have to D/L each time because then it won't be a feasible solution (it currently takes upwards of (20) min to D/L a program)/
Old 10-28-2011, 12:54 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Looking good tony check out what i just ordered
no not from that company but was just the only pic i could get
Old 10-28-2011, 01:45 AM
TonyD87's Avatar
Color: Gray
Those are nice, what size are you getting?
Old 10-28-2011, 03:21 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Damnit dodgert I wanted those! Lol
Old 10-28-2011, 12:45 PM
TonyD87's Avatar
Color: Gray
dodgert do you have the full magnaflow kit or just the muffler? I found the whole kit online for $546.
Lowering a 2011 Ram Express TonyD87 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 15 02-15-2012 11:02 AM
2011 Ram Express Upgrades TonyD87 2011 Dodge Ram Forum 32 10-15-2011 08:48 PM
2011 Ram Express wheel diameter question POWWAG Dodge Ram Wheels And Tires 6 10-14-2011 09:20 PM
2011 Express snrusnak 2011 Dodge Ram Forum 19 07-21-2011 12:37 AM
