Old 11-09-2011, 06:44 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Originally Posted by TonyD87 View Post
dodgert you got your HID kits from carid right? They are the brand notto? When you put yours on did you use the harness with the fuse that goes to the battery?
Yep if not they will flicker.
Old 11-09-2011, 06:55 PM
TonyD87's Avatar
TonyD87 TonyD87 is offline
Vehicle: 2011 Ram 1500
Color: Gray
TonyD87 is on a distinguished road
I saw a few posts on here about HID install when I did mine and no one mentioned using that harness. I just plugged mine in and they work perfectly. I have had them a little over a month now and no problems, not even a tpms problem. Shuold I put that harness on? I think it came with whats called a capacitor? I put those on there. I mean they are rediculously bright.
Old 11-09-2011, 07:04 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
If its not broke dont fix it lol keep it around so if one day you do get the flicker you can fix it but 0 problems id say leave it be.
Old 11-09-2011, 07:22 PM
TonyD87's Avatar
Color: Gray
Yea im just going to leave it. Does the flicker occur just when you first turn them on or do they just have a constant flicker when they are running for a while? I mean when I hit the door unlock button on the keyless button it flickers on for a second and then they are fine, same when I turn the headlight switch on.
Old 11-09-2011, 07:26 PM
TonyD87's Avatar
Color: Gray
It doesnt do that with the fog lights though just the low beams. They just gradually get brighter and it is only for a second and from then on it is fine. What color HID kit did you get? I got the 15000K they are bright and very blue. Im thinking I should have gotten the 10000K instead. DO you know if I can just order replacement bulbs and use the same balast from notto?
Old 11-09-2011, 10:24 PM
v8440 v8440 is offline
Vehicle: 2009 Dodge Ram
Rep:15
v8440 is on a distinguished road
I'm not sure I would go buying a swaybar. My '09 rcsb 2wd didn't come with one, and I don't think not having one is hurting me. I can't for the life of me figure out why it doesn't have one, but I even went so far as to get my build sheet printed out to make sure someone hadn't "borrowed" it when it was still new on the lot. They hadn't-it truly never had one.
'98 12v dually, 450 hp, 920 ft/lbs, ran 14.67 at 98 granny shifting the 5 spd, 278k
Old 11-09-2011, 10:29 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
A sway bar on the back of a truck can be counter productive at the vehicle's limit.
Sean
Old 11-16-2011, 04:05 PM
TonyD87's Avatar
Color: Gray
New parts that I will be installing!! I have a magnaflow catback exhaust, y pipe, K&N intake, billet tech catch can, and a fastman throttle body on its way. I have a local tune shop that said he can tune my truck so I will know about that soon. Is there anything else I can do for performance without voiding my warranty? Once this is done I will be going to see how much an aftermarket torque converter and 4.10 to 4.56 gearing is going to be, anyone got prices on these?
Old 11-16-2011, 04:06 PM
TonyD87's Avatar
Color: Gray
Is it true that there will not be a programmer for the 2011 to 2012 rams? Why is it so difficult to crack the codes on these rams?
Old 11-16-2011, 04:41 PM
snrusnak's Avatar
Rep:1385
There will be tuners, just not right away.
Sean
Lowering a 2011 Ram Express TonyD87 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 15 02-15-2012 10:02 AM
2011 Ram Express Upgrades TonyD87 2011 Dodge Ram Forum 32 10-15-2011 07:48 PM
2011 Ram Express wheel diameter question POWWAG Dodge Ram Wheels And Tires 6 10-14-2011 08:20 PM
2011 Express snrusnak 2011 Dodge Ram Forum 19 07-20-2011 11:37 PM
