Old 10-03-2011, 09:16 AM
atomens2004 atomens2004 is offline
Vehicle: 2008 Dodge ram 1500
atomens2004 is on a distinguished road
Default 2008 ram 4.7 just shut off
Hello all,
i have a 2008 ram with a 4.7. Today while getting on the high way the truck just shut off. i was able to coast the truck to the side of the road. Right before it shut off i heard a pop sound and the motor went dead. tried to restart, did not restart till i turned the key all the way off and let it sit for a min. Got off at the next exit and went to auto zone to see if there was any codes in it. Nothing showed up. Is there anyone that might point me in the right direction to prevent this from happening again. or if anyone has any idea what might have caused this.
Old 10-03-2011, 11:38 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Well has it done it again since you got it running again?
Something like this can't really be prevented Just keep a Eye on Water Temps and Oils and Codes. Check all your Spark plugs for signs of Rich Mixture some times rich mixture can cause backfires in the intake manifold fuel being ignited from the heat. it's not for sure much can be listed for the cause. Has anything Change since it happen like loss of horsepower etc .... ?
Old 10-03-2011, 01:11 PM
Default re info
not sure if this will help. The plugs have about 3000 miles on them they are bosh plugs the same that was in it when i changed them. the Truck has 48000 miles on it. aas far as i can tell it does seem to be a little bit slugish when you get on the throttle. I only changed the intake side of the plugs when i changed them. Do you think it would help to do the other 8 plugs ? This is the 4.7 flex fuel motor. if that helps. The fuel doesnt seem to be that rich still getting about 15mpg the when i got the truck back in Feb. I know its a long shot to find out what caused this to do this till it finally really starts to act up. it has only did it 2 times and was just trying to keep it running right.
Thanks For any help
Andy
Old 10-03-2011, 01:16 PM
Three things to check:
1. Replace the other 8 plugs.
2. Clean your throttle body.
3. Clean or replace your EGR valve.
2008 Ram TPMS Sensors chithead Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 2 02-28-2011 07:56 AM
2008 Switch bezel Rear sliding window and heated seats TALLA Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 01-16-2011 04:11 PM
2008 Dodge 1500 Trany Question newdodgeowner Newbie Checkin! 12 07-27-2010 09:30 AM
Fuel saver Mode shut off ? 2009 Ram Mattylaw21 5.7L (345 cu in) HEMI V8 Specific Topics 4 03-28-2010 10:05 PM
R.I.P. 2008 Dodge Charger Daytona #0480/1650 OKCharger Other Vehicle Discussion 9 07-18-2009 01:18 PM
