Old 10-03-2011, 01:47 PM
Flat Spot Flat Spot is offline
Vehicle: 2011 Dodge Ram 1500 Sport 4x4
Rep:19
Flat Spot is on a distinguished road
Default Anyone Install a Remote Start?
Now that the weather is starting to get cold, I want to install the remote starter on my truck. I'm told and have read that the dealer has to do scan in order for the remote start to work; however, if you install the device at home in your garage, will any of the keys work and start the truck by putting it in the ignition and turning it?
I don't want to install it at home only to find out that it won't start.
Old 10-03-2011, 02:35 PM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
The dealer told me that it had to be done there because you get new key fobs they will keep old keys
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 10-03-2011, 04:12 PM
tonyhawk196's Avatar
tonyhawk196 tonyhawk196 is offline
Vehicle: 2011 Dodge Ram Express
tonyhawk196 is on a distinguished road
From what I understand, All they need to do is program the new key fobs and you should be able to install the new hood latch, module and in some cases the wiring harness yourself. If you look on Mopars website, you can get the kit number and the a pdf of the instructions to install.
The wiring harness looks to be the most difficult piece to install but I believe in most cases you do not even need it because the truck is pre-wired. The instructions explain how to tell if your truck is pre-wired already or not.
But I guess the best bet would to talk to a tech and ask he or she if the hardware install can be preformed by you.
Old 10-03-2011, 05:20 PM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Color: Grey
Rep:27
stangd1909 is on a distinguished road
I'm going to do the same thing. Here is a really nice kit, and for cheap.
http://item.mobileweb.ebay.com/viewi...id=26150143877
Old 10-05-2011, 11:09 PM
Rep:19
That's just wrong. You're buying a new module with new keys, so they should program the old keys (which you own) with the new module and give you back the old module. They shouldn't be keeping anything.
Old 10-05-2011, 11:32 PM
kewlguy53403 kewlguy53403 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:25
kewlguy53403 is on a distinguished road
There is a module out there that plugs in under your dash and you can use your existing keyfobs for. I had it installed, it was part of the deal when I bought the truck, he put it in for his 'cost' ($180 - cheap enough for me). I watched the guy do it, it took about 5 mins, unscrew 2 screws, unplug connectors, put remote in between connectors, program, screw, done. I'm not sure what/where you can get it though.
Raptor Step & Bed Rails | K&N | BakFlip HD | Halo Proj. LIghts | Recon Brake Lights | DDM HIDs | Big Rig Lights | Night Raider Taillight Bar | Volant CAI | Magnaflow 18 | MGP Caliper Covers | Lower Billet Grill | 20% Tint | Blistein 5100 @ 2.8 | 34" Tires | Dipped Chrome
Old 10-06-2011, 01:09 PM
pall2509 pall2509 is offline
Vehicle: 2001 Dodge Ram
pall2509 is on a distinguished road
My dealer updated old keys, I have 4 keys (fobs) to run truck, only 2 w/remote start.
Old 10-09-2011, 07:13 PM
hector22's Avatar
hector22 hector22 is offline
Color: Mineral Gray
hector22 is on a distinguished road
My dealership said they could not reprogram my old key fobs, probably just lazy. Damn, i will deff go back and have them do it.
Old 10-09-2011, 10:15 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
How much is it to go back to the dealer and have the remote start installed? Im dreading winter
2011 Big Horn 4x4 -SnowWhite-
Old 10-09-2011, 11:04 PM
californiajed californiajed is offline
Trim Level: Crew Cab
californiajed is on a distinguished road
FWIW, my dealer installed the OEM remote start for me when I bought the truck. He charged me $505 for it. I think that's $150 or so more than having it as an option from the factory. It came with two fobs that have the remote start button on them. Unlike you, I wanted it to cool down the truck when it sits in the sun!
Factory Remote Start Install 2007 Ram 1500 Quad Cab dksram Dodge Ram General Discussion 18 03-16-2013 07:35 PM
Windows rolled down and remote start disabled Bjoseph24 2011 Dodge Ram Forum 6 09-25-2011 04:08 PM
RKE and Remote start billzthe1 Electrical 13 07-23-2011 01:38 PM
Remote Start Question sylawter Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 11-09-2010 11:23 AM
Ipod Integration and Remote Start My Sport Lariat Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 02-23-2009 12:39 PM
