Anyone Install a Remote Start? - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-10-2011, 06:56 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Is this something we can still on our own or does the PCM have to be flashed?
Electrical work doesnt scare me
2011 Big Horn 4x4 -SnowWhite-
Old 10-10-2011, 07:34 PM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Vehicle: 2011 Dodge Ram
Color: Grey
Rep:27
stangd1909 is on a distinguished road
It has to be flashed by the dealer. You can install the kit yourself to save a few bucks if you want.
Old 10-11-2011, 04:40 AM
Green 1500's Avatar
Green 1500 Green 1500 is offline
Vehicle: 2011 Dodge Ram 1500 QC
Color: Hunter Green
Rep:17
Green 1500 is on a distinguished road
I talked to my dealer when i bought the truck. They want 300 for the parts and install. I read the pdf and it comes with two new fobs. The dealer says that the new fobs are programmed to the computer so you will have two old fobs that work but dont have the auto start button on them. Then you will have the two new fobs that come with the kit that have the auto start button on them.
If you read the instructions with the kit, it say that it has to be programmed for the module to work. It also says that you can install everything in the kit EXCEPT for the key module. You will have to take it to the dealer and install it there. If you install that module and start the truck you will not be able to program the module and you WILL have to buy a new one. FYI.
Old 10-11-2011, 05:18 AM
Green 1500's Avatar
Color: Hunter Green
Rep:17
Here is the disclaimer:
page two of instruction manual
**this is verbatim**
CAUTION:
XBM remote start can ONLY be installed on vehicles that have the following factory options: Automatic Transmission, Remote Keyless Entry and Immobilizer.
WinFobik based vehicles, the sales code must be added to the database and the Restore Vehicle Configuration (using the StarMobile tool) must be performed prior to installing the new WIN module. Failure to do so will render the WIN module's remote start function inoperative.
Old 10-11-2011, 08:43 AM
SS4Luck's Avatar
Rep:310
Okay, so we know the Mopar one is cool and all with the integrated keys yada yada yada.... but what about an aftermarket one? I almost got one that let me lock unlock start etc from my smartphone and came with a better alarm as well.
what is everyones thoughts on that?
(just trying to play devils advocate with options here)
Old 10-11-2011, 12:04 PM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
i can't weigh in on aftermarkets for this truck (had one on my old Sierra though), but i will say that i'm impressed with the quality of the factory remote start. the range of the keyfob is pretty incredible...better than my "1500 ft" aftermarket i had on my Sierra. also the truck automatically detects whether it's hot out or cold out and turns on the A/C or heat accordingly.
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 10-11-2011, 07:14 PM
SS4Luck's Avatar
Rep:310
now that part i did not know and would definitely make the factory one worth it.... guy time to start scouring egay/amazon
Old 10-11-2011, 07:27 PM
hoyter hoyter is offline
Vehicle: '11 1500 sport 4x4
Trim Level: sport 4x4
Color: mineral grey
Rep:13
hoyter is on a distinguished road
Only if you have dual climate. If you have manual climate controls, it does not automatically set the ac/heat. Though you can manually set them before you get out.
Old 10-11-2011, 11:54 PM
AZBen AZBen is offline
Vehicle: 2011 Ram 1500 ST QC
Color: Gray
AZBen is on a distinguished road
I had a Viper alarm installed in my truck with remote start.
It can be done for right around $400 installed... I had some upgrades added, but with the addition of an alarm on top of the KE, I couldn't stick with the factory stuff.
Old 10-12-2011, 12:12 AM
Rescue1 Rescue1 is offline
Rep:64
Rescue1 will become famous soon enough
You can do an aftermarket one as you stated, and can get a lot more options out of the unit vs the factory one. For instance in my '04 I had the units pulsed negative outputs control my headlights, my reverse/upper cab lights and had another output to turn the heated mirrors on after the truck started. This of course was a lot of work and I needed to build an external latching circuit to make most of the funcitons work..
Also, you would obviously have to have the aftermarket key fob along with the factory integrated key fob because that's your key now, where as before you could just dump the factory remote. Not a big deal but just more to have in your pocket. For any installers out there it isn't a terribly hard install but you will need the DBALL unit to integrate the aftermarket brain into "tricking" the truck to start. You however will not have to sacrifice a key like the old transponder units.
If your just looking for an Auto start and nothing else, I would do the factory unit yourself and then take it to the dealer to be flashed. I haven't done one yet myself, but the instructions look super simple..
Factory Remote Start Install 2007 Ram 1500 Quad Cab dksram LD RAM - General Discussion 18 03-16-2013 07:35 PM
Windows rolled down and remote start disabled Bjoseph24 2011 Dodge Ram Forum 6 09-25-2011 04:08 PM
RKE and Remote start billzthe1 Electrical 13 07-23-2011 01:38 PM
Remote Start Question sylawter Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 11-09-2010 12:23 PM
Ipod Integration and Remote Start My Sport Lariat Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 02-23-2009 01:39 PM
