United Radio
Old 10-03-2011, 03:34 PM
RAMitDOWN's Avatar
RAMitDOWN RAMitDOWN is offline
Vehicle: 09 Dodge Ram
Trim Level: ST 4X4
Rep:24
RAMitDOWN is on a distinguished road
Default Power Control Module
Had my Ram die on the way home from work last week, coasted to the side of the road put it in park and it started right back up.
After restarting it the CEL came on so I took it to the dealer and was told it needs a new PCM.
Just checked back with them today and was told it (PCM) is on back order and looks as though there are 15 (+/-) ordered nation wide.
How long does usually take for back ordered items ?
Anyone else heard of a problem with these in 09's ?
Old 10-03-2011, 04:44 PM
DBryant DBryant is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT, Big Horn
Color: Crimson Red
DBryant is on a distinguished road
Had mine replaced on my 2010 about a year ago. Only took a couple days to get it. Of course they didn't say anything about back orders. Hope you get it soon.
Old 01-03-2012, 10:55 AM
RAMitDOWN's Avatar
Trim Level: ST 4X4
Rep:24
Had a second Power Train Control Module replaced last month (Dec 9/ 2011).
Now this morning on the way home from work the same deal truck died going down the road at around 55 MPH.
I pulled over restarted and the check engine light is on again I'm guessing it's the PCM each time the same thing.
If I'm correct this will be the third replacement what really gets under my skin about this is that it is cutting into my time bow hunting (again) and we only have a couple weeks left before the season ends.
I put a hole 650 miles on the truck since the last PCM replacement.
Old 01-03-2012, 12:14 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds like your dealer is going to have to find out why this is happening. IMO you shouldn't be having multiple PCM failures. If it was that big of a failure issue, I'm sure this forum would be littered with posts like yours, so there must be something else that is the underlying cause of this. The last thing you need is to have this issue when the warranty is run out. The PCM is not a cheap part.
brad
Interested in one of my mods?
Old 01-03-2012, 03:48 PM
RAMitDOWN's Avatar
Trim Level: ST 4X4
Rep:24
My thoughts exactly.
Last time they replaced it I brought this up I'm not a mechanic but it seems to me if it keeps happening something else is causing it.
The service guy at the dealer claimed they must have just had a run of bad PCM's because they had 2k - 3k on back order both times.
Sounded like a line of BS to me.
The factory warranty is over (36417) but this falls under the lifetime "drivetrain" warranty they had for 2009's is what I was told.
Old 01-03-2012, 10:36 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
I hope that it falls into the Lifetime Powertrain Warranty, and they are not just covering it because it is an on going problem and it is so close to warranty. I never have seen a detailed list of what it covers.
Hope you get a "good" one this time.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 01-06-2012, 01:24 PM
RAMitDOWN's Avatar
Trim Level: ST 4X4
Rep:24
Just returned from the dealer
No new PCM this time but they did have to give it a flash update for P0524 Oil Pressure Rationality (TSB 18-19-09).
Hopefully I wont need another trip to the dealer any time soon.
Old 05-09-2012, 01:24 PM
RAMitDOWN's Avatar
Trim Level: ST 4X4
Rep:24
Thought I would update this.
After the last trip to the dealer (01/12) for a computer flash my truck was still randomly shutting down while I was driving down the road at highway speeds.
Since the last flash the CEL never comes on though.
It usually looses power all the warning lights come on and the gauges drop then after about 5 seconds everything comes back up/on and I continue down the road, no CEL light.
Other times it shuts down completely and I have to pull over and restart it, still no CEL.
Seems as thought the last computer flash was to just keep the CEL from coming on ? lol
I have been just ignoring it because it wasn't happening frequently but today was the last straw it's retuning to the dealer Friday.
I'm sure the result will be the same, another computer flash and it will continue to shut down on me at some point and time.
Sometimes it takes a week before happening other times just a few days once in a while I get lucky and it will last a month before shutting down.
sorry for the rant.
Old 05-09-2012, 04:57 PM
Hemi390's Avatar
Hemi390 Hemi390 is offline
Vehicle: 09 Ram 1500 Crew Cab 4x4 3.55
Rep:27
Hemi390 is on a distinguished road
Sorry to hear about your troubles keep posting the results
K&N drop in ,Debadged except tailgate ,1200 watt power inverter ,Bed rug ,LEER 800 tonneau
Old 05-10-2012, 03:07 AM
brad12kx's Avatar
Rep:2581
You sure don't have to apologize for the rant. Under the circumstances, I'd say your in your right to be upset and ranting.
When you take it in, maybe suggest they check the TIPM....specifically the connectors on the bottom of it. When a truck has intermittent issues, I often go through the motion of removing and reattaching these connectors to cycle the contacts. Since the TIPM supplies ALL the power to ALL the systems, a poor connection on one of it's connectors could cause PCM issues. It doesn't cost anything to do this and only takes about 15 minutes.
Keep us posted.
brad
P1128 p1129 firecadet613 5.7L V8 Specific Topics 8 04-19-2013 11:52 PM
2009 Dodge 3500 SeaCaptain 2009 Dodge Ram Forum 4 10-10-2011 02:50 PM
over head console ram man Electrical 1 10-17-2010 02:41 AM
Commonly Used Chrysler Acronyms RamTech Dodge Ram Knowledge Base 3 01-13-2010 01:43 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 01:36 PM
