Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 05-19-2012, 10:59 PM
storeboy storeboy is offline
Vehicle: 2009 Dodge Ram
Rep:19
storeboy is on a distinguished road
Does anyone know if you can you take a PCM from a '10 Ram and put it in an '09?
I have read through the forums that they used one manufacturer of the PCM for '09 and had problems. In '10 they went with a different manufacturer and problems went away. Well apperantly between now and then the manufacturer of the '09 PCM went by-by and they are now hard to get (which is why you had to wait so long and I had to way 2.5 months when I had mine replaced last year).
Since the '09's have problems and the '10's don't, is there any reason why we can't swap?
Old 05-19-2012, 11:58 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1217
How much does all this swapping cost if you are say, out of warranty?
I would think the only thing needed after a PCM swap from a 2009 to a 2010 would be a flash at the dealer so the EVIC works correctly.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. 60k Miles. 5100's @2.8 Adj Coilover front struts. 3" Lift done my way. BF-Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, spray-in Liner, Mud Flaps, 20% tint, SS Side Steps, TruXedo Roll-up Soft Tonneau, SS Bull Bar, 10k Lumen 22" Solidex LED Bar, DZ Tailgate assist, TLC, AVS Visors and Bug Shield, K&N, XenonDepot 5000k HID Headlamps in projectors.
Old 04-26-2013, 04:43 PM
calizeus calizeus is offline
calizeus is on a distinguished road
Reading through these posts, because I think I might have a PCM problem.
First off, I'm going to do some internet searching to see if I can find out, but what is "TIPM"? Where is it located in 2009 Ram (Hemi engine), and anything special I would need to know about in disconnecting and reconnecting the connectors?
On to what brought me here originally. My truck is acting strange to say the least. Intermittenly over the last several months, my truck won't start in the morning. The battery will be drained. But, in having the battery tested, it tests fine. (I also think the battery is fine). I also have issues with the remote start just starting my truck whenever it feels the urge, the lock button on my key fob not locking the vehicle, but unlock works fine. I've also had it in a couple of times for the controls for heat/cool not working right. That was something to do with doors opening or closing directing the air. It just seems to be alot of things that are making me start to point to a faulty brain, and isnt' the PCM basically the brain?
Also, has anyone gotten confirmation on whether the PCM is covered under the Powetrain Warranty. I am at about 46k, and am out of the 36k / 3 year warranty.
Thanks in advance for any replies.
Old 04-29-2013, 09:57 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
TIPM = Totally Integrated Power Module. It is the thing under the hood that is often called the Fuse Box cuz it also houses all the fuses.
Based on your symptoms, I will be very surprised if you have a PCM issue. It sounds more like Instrument Cluster or TIPM. I'd start by cycling all the connectors on the TIPM.
brad
Interested in one of my mods?
P1128 p1129 firecadet613 5.7L V8 Specific Topics 9 03-06-2015 02:52 AM
2009 Dodge 3500 SeaCaptain 2009 Dodge Ram Forum 4 10-10-2011 01:50 PM
over head console ram man Electrical 1 10-17-2010 01:41 AM
Commonly Used Chrysler Acronyms RamTech Dodge Ram Knowledge Base 3 01-13-2010 01:43 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
