Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 10-03-2011, 03:52 PM
RedDodge's Avatar
RedDodge RedDodge is offline
Vehicle: 2014 Dodge Ram
Color: Granite
Rep:25
RedDodge is on a distinguished road
Default HELP...Slid down the defrost vent!
Hopefully some one can help me...I had a decorative chain sitting on my dash and it slid down into the right side defrost vent. I could see it at first but then while trying to get it out I pushed it in deeper.
So the question is......what's my best plan of attack to get it out! Where does that vent go? I took the glove box out but really can't see to much that far forward.
Any help would be greatly appreciated!
Thanks,
Steve
Steve
www.monteman.com
Mods: Tinted front windows, UnderCover tonneau bed cover, step rails, bed mat, cabin air filter, 4 corner mud flaps, slush mats, drop in K&N filter.
Old 10-03-2011, 03:58 PM
RedDodge's Avatar
Color: Granite
Rep:25
Default HELP...Slid down the defrost vent!!!
Thanks,
Steve
Steve
www.monteman.com
Old 10-03-2011, 04:07 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Try a strong vacumm with the smallest attachment on it to get as far in as you can, use a nylon ( womens stocking ) as a filter in between one of the joints so it doesnt go into the actual vac/bag. I dont know how deep your vent is but its usually anywhere from 1-1/2" to 4" deep, they are plastic pockets with a flexible hose attached from the fan housing most likely adeflector box that controls the airflow. If you hear something that sounds like a fork in the garbage disposer...youll know where it went...lol
J/K... Hope you get it out. Another way to see if you can see it is using one of those little inspection mirrors so you can angle it to see down the vent. Only other way would be to pull the dash apart to access the vents.
Mike
Old 10-03-2011, 04:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I agree try the vacuum trick (do what he said to keep it from actually being sucked into the vacuum....). You have to "seal" it though, you can use tape or something to take the vacuum hose around the vent to seal it....that MIGHT work, but probably not honestly as a chain is probably heavy. I'd try like he said a little mirror for sight....and maybe one of those magnetic extendable wands...
Sean
Old 10-03-2011, 04:53 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
A small pick up magnet maybe? your local auto store or walmart may have a pickup tool that has three claws and is flexible. you depress the plunger on one end and three claws come out the other when you release plunger they retract and grab small items, its about 24" long. You might try "fishing" with a tool such as this. it was like $3-4 at my local tool store
Old 10-03-2011, 05:23 PM
RedDodge's Avatar
Color: Granite
Rep:25
Thanks guys...called the dealer...10 hours of labor and $1,100 to pull a $2 chain out of the vent....lol..... I did the inspection mirror with a piece of wire and was able to fish it out!!!!!!
I was just afraid that I'd have to listen to it jingle around in there forever......
Steve
www.monteman.com
Old 10-03-2011, 05:27 PM
Crash's Avatar
Rep:401
So that means you now have $1100 for mods!!!! lucky you, what are you going to get Glad it worked out for you bud
Old 10-03-2011, 10:19 PM
moparornocar72's Avatar
Rep:630
Best advice I have for you is take the glove box back out and shine a light down from the top of that vent, see where the light shines into and then proceed from there. If you need any diagrams let me know
14.268 @ 95 MPH Full Trim
Old 10-03-2011, 10:24 PM
And when you do that ^^^^ have one of those magnetized pickup tools that extends.
The other option is to remove the defroster vent panel (it should just pop off) for a better look and maybe you can reach it from the top.
Old 10-08-2011, 12:51 PM
Razorback's Avatar
Razorback Razorback is offline
Vehicle: 2011 Ram Crew
Color: Deep Cherry
Razorback is on a distinguished road
Should be able to find one of these at just about any auto parts store
http://www.harborfreight.com/24-inch...ool-94162.html
Growing old is inevitable, growing up is optional.
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 16 02-11-2015 06:32 PM
HVAC: Air (heat) Only Comes Out Defrost Outlet 07STMPULR Heating & Cooling 2 01-26-2011 10:41 AM
no Defrost! jmtertz Heating & Cooling 8 11-10-2010 04:54 PM
What is the purpose of the Vent between the Bed and the Cab? RammD Dodge Ram General Discussion 13 11-07-2010 01:19 AM
2004 Dodge 2500 intermittent defrost issue r1buden Heating & Cooling 2 03-20-2010 11:30 AM
