Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 10-03-2011, 07:00 PM
moparornocar72's Avatar
Rep:630
Post How To, Remove Transmission and Torque Converter
I was asked by a member to pull up some info about removal of the torque converter and since the transmission has to be removed I figured I would throw that info in as well. Here it goes :
Transmission Removal:
1. Disconnect the negative battery cable.
2. Raise and support the vehicle
3. Remove any necessary skid plates.
4. Mark propeller shaft and axle companion flanges for assembly alignment.
5. Remove the rear propeller shaft
6. Remove the front propeller shaft, if necessary.
7. Remove the engine (1) to transmission (3) structural dust cover (2).
  1. Remove the exhaust support bracket from the rear of the transmission.
  2. Disconnect and lower or remove any necessary exhaust components.
  3. Remove the starter motor.
  4. Rotate crankshaft in clockwise direction until converter bolts are accessible. Then remove bolts one at a time. Rotate crankshaft with socket wrench on dampener bolt.
  5. Disengage the output speed sensor connector from the output speed sensor (2).
13. Disengage the input speed sensor connector from the input speed sensor (2).
  1. Disengage the transmission solenoid/TRS assembly connector from the transmission solenoid/TRS assembly (2).
15. Disengage the line pressure sensor connector from the line pressure sensor (2).
  1. Disconnect gearshift cable (1) from transmission manual valve lever (3).
  1. Disconnect the transmission vent hose from the transmission.
  2. Support rear of engine with safety stand or jack.
  3. Raise transmission slightly with service jack to relieve load on crossmember and supports.
  4. Remove bolts securing rear support and cushion to transmission and crossmember.
  5. Remove transfer case, if necessary.
  6. Disconnect transmission fluid cooler lines at transmission fittings and clips.
NOTE: When disconnecting the transmission oil cooler lines, it is necessary to replace the line clip that is located on the oil pan stud. The retention force of the clip is severely degraded upon removal.
  1. Remove all remaining converter housing bolts.
  2. Carefully work transmission and torque converter assembly rearward off engine block dowels.
  3. Hold torque converter in place during transmission removal.
  4. Lower transmission (2) and remove assembly from under the vehicle.
And Now the torque converter instructions:
CAUTION: Verify that transmission is secure on the lifting device or work surface, the center of gravity of the transmission will shift when the torque converter is removed creating an unstable condition. The torque converter is a heavy unit. Use caution when separating the torque converter from the transmission.
27. Pull the torque converter forward until the center hub clears the oil pump seal.
28. Separate the torque converter from the transmission.
14.268 @ 95 MPH Full Trim
Old 10-03-2011, 09:13 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Thank you buddy!
Sean
Old 10-03-2011, 09:44 PM
Rep:630
anytime I just hope you can get the line clip it was talking about in the notes. When you take yours out, don't forget to take some pics and add to this!!!!!!
Old 10-03-2011, 09:50 PM
snrusnak's Avatar
Rep:1388
Yeah I wouldn't have known to do that. I will add to this when I do it, hopefully sooner than later, but may be a few months(depends on the bank account lol)...It will happen though as I bought a converter from another member on here and it should arrive tomorrow . Maybe I'll get the itch and install it sooner than I think haha... I just want to make my ram air to finish my intake, and do my exhaust first...
Sean
Old 10-03-2011, 09:52 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
Nooo you told him!!!! Now he's going to install that darn TC of his!!! lol
Thanks for the public info....
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 10-03-2011, 09:55 PM
Rep:630
Haha like any other member on here. all you have to do is pm me and I will get as much info and service info as I can! What converter you going with?
Old 10-03-2011, 09:58 PM
snrusnak's Avatar
Rep:1388
Bought an edge street edge 2800 from a member here, will probably stall a little higher for me....as my 4.7L has a little less output than the 5.7L he had...
I want to make my ram air first just to have my intake 100% complete, and I want to do my exhaust first because I'd have to remove a lot of the exhaust to get the trans out, but I'm going to move the exhaust crossover to behind the trans when I do the exhaust so it will be out of the way....so it just makes sense to do it first...
Sean
Old 10-03-2011, 10:10 PM
Rep:630
completely, good luck! let us know how it goes!
Old 01-26-2015, 08:38 PM
wagonburner wagonburner is offline
Vehicle: 2004 3500 Ram
Trim Level: SLT Quad Cab
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
wagonburner is on a distinguished road
moparornocar72. any chance you might have the same information for a 5.9 Cummins.
thanks
545RFE transmission service step by step snrusnak Dodge Ram Knowledge Base 47 09-24-2016 11:50 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Just ordered Arrington Big Valve Heads RamTex Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 19 07-08-2011 02:38 PM
Need To Tow Something Heavy? How About 800 Ft. Lbs. Of Torque? RamTech LD RAM - General Discussion 5 02-14-2011 08:43 AM
Removal of transmission MrDodge300 5.2L V8 Specific Topics 2 01-16-2011 03:49 PM
