Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-05-2011, 08:27 AM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
Had my 2010 done last Friday. Both outer tie rods ends and alignment - no charge.
They also found both hub bearings were bad (noisy and rough) - replaced both hubs, no charge.
Feels like a new truck again!
Old 10-05-2011, 10:26 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Well I guess every dealer is different, which is basically frustrating when you purchase a 40k plus vehicle. I ended up having to swap dealers for this work because my usual dealer was stating that they would only check the tie rod ends, and then replace only if need be even though the recall stated that they were to be replaced. Idiots.
So, I now drive 40 plus miles to another dealer that has their act together. They did the recall and reset the toe.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 10-05-2011, 11:14 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Color: Burgandy
Rep:160
I just got my outer tie-rods replaced last week, they set the toe, before I had this done my steering wheel sat left a touch and a very slight pull to the right, after the tie-rods and toe, the wheel is perfectly centered and the pull is gone. So I pull out my work order today and it states beside note "needs alignment", lol, un****en believable! lol. I burned up a couple of days off, travelled 150 miles to my dealership to get this done. No mention of the fact when the truck was ready it needed an alignment. Kinda burns my ass a little.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE COMING SOON!
Old 10-05-2011, 12:14 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Originally Posted by TheRocketmac View Post
Just had this done last Friday... Said I needed a full alignment that (was not covered) by the recall. However, my local dealership isn't the best.
If they told you this before they looked at it they lied or they're stupid. Yes you do need an alignment but not complete though they should check the complete alignment after they do the work for safe keeps. Everyone one should, there's no telling what damage these faulty tie rod ends could have caused. edit: After watching this idiot kid (it was funny) at my dealership do my last oil change (trans), you can believe I'm having mine completely checked. He raised the drain pan all the way up to the tranny before he loosened the bolts so he had trouble trying to get the tools up in there to take them out. Finally...with the pan hanging downward he got the last one out and knocked the it to the ground and spilled the oil all over the place. I can imagine these people taking my whole front end appart to change my tie rod ends...you'll definately need one then, lol!
Old 10-05-2011, 01:36 PM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:54
Ramathorne will become famous soon enough
Mine drives like new again (shocks, mounts and outer tie rod ends)
Going to get a free alignment whenever I make an apt
Old 10-06-2011, 10:51 AM
firedad70 firedad70 is offline
Vehicle: 2009 Dodge Ram
firedad70 is on a distinguished road
Took mine in this Tuesday for the bad knock on cold starts, they did the tie rods and a few other things, of course had to order the bolts for the manifold leak, big surprise.
Old 10-06-2011, 11:54 PM
quadx350's Avatar
quadx350 quadx350 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Dark Red
quadx350 is on a distinguished road
Do any of you guys know if you have a leveling kit installed would that void the recall? When I first got the truck the mechanic mentioned that one of my tie rods where alittle loose. thanks
interior LEDS, LEDS under seats, Leveling kit, Dick cepek 18 inch rims, 33 inch tires
Old 10-07-2011, 01:12 AM
RadioFlyer's Avatar
Rep:146
No it does not void the warranty. They tried that at first in 09 and Chrysler lost and were replaced with the same type faulty parts. Then later had to replace the tie rod ends a second time for the recall with improved parts on the same lifted and lowered trucks.
Old 10-07-2011, 01:25 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
When my 2/3 lowered 10' 4x4 was waiting in line to book it in for the recall there was matching Black 10' with a 6" lift/35's in front of me.
Both were done under warranty no questions asked. (BTW only alignment done was toe adjustment, caster and camber are not effected)
Old 10-08-2011, 09:49 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Got mine done all seems well up there but I only have just under 20,000kms or 12,000miles
New Recall k36 found it today at Dodge dealer - REAR AXLE FLUID DRAIN-BACK FLOW RESTRICTOR - Pic RAMTX 2011 Dodge Ram Forum 131 09-23-2011 11:36 PM
2010 Recall - K08 RamTech Dodge Ram Recalls and TSB's. 6 02-25-2011 04:13 PM
My brake recall experience quadbob 2010 Dodge Ram Forum 2 12-06-2010 11:58 PM
recall aolslayer 5.2L V8 Specific Topics 1 08-07-2010 09:19 PM
09/10 recall txhemi Dodge Ram Recalls and TSB's. 8 01-21-2010 01:08 PM
