Old 10-03-2011, 09:54 PM
Dodgerman1 Dodgerman1 is offline
Vehicle: 2002 Dodge Ram 1500
Color: Midnight Blue
Rep:22
Dodgerman1 is on a distinguished road
Default Heater probelms
I have the 4.7 quad cab does not have dual climate control.
My passenger side heater works perfect and HOT! but my drivers side is is blowing cool air. I have been losing coolant from a head bolt or gasket i belive. any ideas on it?
Old 10-03-2011, 10:27 PM
02Ram4x4 02Ram4x4 is offline
Vehicle: 2002 Ram
02Ram4x4 is on a distinguished road
i dont have the coolant leak, but my driver air ducts dont blow hot air either, but the passenger side works great, your coolant leak is most liklely not the culprit,i havent been able to check this yet, but the trap doors in the dash that direct hot/cold air are electricly controlled, someone correct me if im wrong, so if thats the case it might be a stuck door, or maybe if its vaccum controlled then the vaccum line could have a leak, also i might add that after about day of running the heat the drivers side starts to work its very weird, i suspect blockage!
Old 10-05-2011, 09:30 PM
starquestbd22's Avatar
starquestbd22 starquestbd22 is online now
Trim Level: Sport quad cab
Rep:367
Yes, the Ram HVAC modulation doors are electronically controlled and prone to failure. If you haven't already check out this site....
http://heatertreater.net/Ram%2002-08%20Listing.html
Read it all if you have time. It's great, detailed information. Sounds like you might particularly be interested in the section on blend door failure. Good luck!
Old 10-06-2011, 12:30 AM
Vehicle: 2002 Ram
that page has great info, thank you for the link i wiash i would have posted a while back to fix this problem, i believe i'll be fabricating my parts considering the first charge is 119.99, but again thank you
Old 10-06-2011, 05:08 PM
Rep:367
Yeah, can't blame you. I don't remember where I learned about that site but it is awesome. The only issue I have had so far is the recirc door. It's stuck open so in the winter cold air comes in the external intake and flows out the internal intake onto my wife's feet, lol. I need to fix it before we start getting really cold weather this year. Like you, I am going to try to fix it myself before I pony up the cash.
Old 10-07-2011, 03:05 PM
willpon1728 willpon1728 is offline
Vehicle: 2003 Dodge Ram 1500
Color: Tan
willpon1728 is on a distinguished road
I had same issue. 2003 Dodge Ram no heat drivers side.I replaced tstat,radiator ,2 blend doors & recirc door. Still no heat. I flushed out heater core 1rst with water then with my air compressor. My heat is now working 100% better than it has in years.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Serioius heater confusion znowybird Heating & Cooling 3 02-13-2011 10:49 PM
having a little heater issue, ( PLEASE HELP ) mark1963 Dodge Ram General Discussion 0 12-19-2010 12:31 AM
Engine Block Heater MasterBlaster 2010 Dodge Ram Forum 25 11-28-2010 12:18 PM
Factory Engine Block Heater / Remote Start 10ramisport 2010 Dodge Ram Forum 17 10-18-2010 11:15 AM
