Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-03-2011, 10:24 PM
DodgeGuy85's Avatar
DodgeGuy85 DodgeGuy85 is offline
Vehicle: 1996 ram 2500 4X4
Color: Blue
DodgeGuy85 is on a distinguished road
Default Rough Idle...
Hey guys had a question for anyone who has experience having a rough idle with there trucks. I have a 96' slt with the 5.2,auto. 2 wheel drive and has started a rough idle when sitting at a redlight but when I go to neutral it smooths out. The needle goes up and down a little when in gear and its idling and can feel truck shaking a little. I went trail riding over the weekend and got a little too deep into water so Im thinking maybe its water somewhere or maybe the coil pack going out the reason I say coil pack is because it feels like its missing but when I get it up to speed it runs smooth with no popping like if it was missing.Kinda hoping that someone on here has had the same issue and has figured it out. Im not a mechanic but can do a little I cant afford for this thing to brake down so any help would be a big help ! thanks for any input in advance.
Old 10-06-2011, 09:27 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
for a simple check id say take ur cap off and see what kind of shape its in?? maybe its holding the moisture in the cap but if its smoothin out in neutral id say an electrical problem so id have to think about that one a bit.
Is it throwing any codes?
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 10-06-2011, 09:46 PM
DodgeGuy85's Avatar
Color: Blue
Thats kinda what I'm thinking yesterday I changed the upstream 02 sensor,new air filter cleaned the throttle body and iac and cleaned out the gunk where it bolts in at.Changed tranny fluid and filter and with doing that It made a good difference with the Idle.Before I did all that the check engine light was on and after I was done I disconnected the terminals to get it to shut off and drove to work today with it off but on the ride home it came back on.My abs light had been on too so maybe it has something to do with that.I hav'nt hooked it to a scanner yet for a code reading but I think this weekend Ill get it somewhere and get it looked at.
Old 10-07-2011, 01:45 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
not sure bout the rough idle, but the abs light dont have anything to do with the check engine light, since you disconnected the battery and it came back i would get it scaned (should be able to do it free at a local auto parts store)
Old 10-13-2011, 07:26 PM
98redbull2's Avatar
Rep:52
getter checked out and let us know
2011 Hemi Rough Idle Eurotrash 2011 Dodge Ram Forum 11 09-24-2014 02:25 PM
Rough Idle, Bad mileage, EGR valve? madmax0r 5.9L V8 Specific Topics 11 01-29-2012 10:08 PM
Low idle, rough idle problem and more starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-17-2012 04:03 AM
Rough Idle when first started 2002Sport 5.9L V8 Specific Topics 16 07-21-2010 03:01 PM
New 2010 Hemi Rough Idle jimw 5.7L (345 cu in) HEMI V8 Specific Topics 3 06-20-2010 02:07 PM
