Old 10-02-2011, 09:09 PM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
Default 97 ram valve cover breather... can you plug it?
so my question is on my ram driver side valve cover has this breather. can i plug it or does it need to be open... it was hooked into my intake was told all it did was throw exhaust into the intake for fuel economy on the highway.. i bout 2 rubber caps one for my intake and one for the breather.. was just making sure if i plugged it nothing bad is gonna happen
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
Old 10-02-2011, 09:25 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
i wouldnt plug it, go to the parts store and by a valve cover breather. its there so the crankcase can "breathe"
Old 10-05-2011, 09:40 PM
Okiespaniels's Avatar
Trim Level: Fleet
Rep:47
That breather is the intake for the PCV system that allows it to intake fresh air so the engine can suck it into the combustion chamber and try to burn it off. WHile it may rob some power, just plugging it will have even more serious consequences.
FYI if you plug it your crankcase pressure from your engine will have no where to go.
And like electricity it will see the path of least resistance, meaning a weak or loose gasket will start leaking. Sometimes on older engines the "oil down" is pretty spectacular.
So rather than plug it off I would run ot back into your intake(you mean air filter assembly right). The filter simply cleans the incoming air. Then it passes through your motor mixing in with crankcase ickies and is sucked through the pcv valve into your intake manifold and then burnt in the combustion process.
I'm confused with the exhaust part of your description. You're not describing a one way or anti backfire valve for the egr system are you?
Old 10-05-2011, 10:41 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Without Positive Crankcase Ventilation, the gases in the crankcase will build in pressure til they force a gasket failure in the engine, or the plug you put in place will become a projectile. The thump you hear will promptly be followed by billowing flames. Pull over and break out the mellows. To a lesser result, it may just make the engine run rough/badly. The PCV is a necessary device, much safer than an overboard dump tube.
Old 10-06-2011, 09:27 AM
ramandstihl's Avatar
ramandstihl ramandstihl is offline
Vehicle: 1995 Dodge Ram
Trim Level: Base
Color: Metallic Silver
ramandstihl is on a distinguished road
i've seen guys try to plug the pcv and breather on both covers and it causes a lot of mayhem. mostly just oil pan gaskets, but i've seen weak head gaskets go too.
Old 10-06-2011, 11:38 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Everyone else covered it, do what I did and buy a filter, dont plug it. Check my how-to in the knowledge base forum
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 10-06-2011, 11:53 AM
mr.lopar's Avatar
Rep:192
this pic you can see the breather i have on mine
Old 10-07-2011, 01:09 AM
Trim Level: ss/t
Rep:44
yo in the pic. is that a gold or yellowish tbs?
Old 10-07-2011, 01:51 AM
Rep:2657
vehicles before 1960 had a downdraft tube at the rear of the engine, excess pressure was sucked out of the engine by wind passing the lower end of the tube, the tube had a point on it, that went towards the front & the shorter cut side went towards the transmission, the image below shows the angled cut
then came along SMOG devices, the hole where the tube had been was sealed off & they started using PCV valves in the valve cover with a hose that fed into the air cleaner
http://cgi.ebay.com/ebaymotors/CHEVY...item5645aced8d
Old 10-07-2011, 11:20 AM
mr.lopar's Avatar
Rep:192
its like a orangish plastic that looks like a block of wood in person, when i can get teh money to get gaskets to swap out my heads and intake itll be coming off so i can fit a 14x3 aircleaner on. btw the tb spacer is made by trickflow
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
hole in the valve cover!?!?! NCDEVILDOG 5.9L V8 Specific Topics 6 03-04-2011 01:06 PM
Valve Cover Leaking nauticstar 2110 Cummins Diesel Specific Topics 6 02-01-2011 08:35 PM
