Old 10-04-2011, 07:14 PM
genesis5521's Avatar
genesis5521 genesis5521 is offline
Vehicle: 2011 Dodge Ram 1500 Tradesman
Trim Level: Tradesman
Rep:32
genesis5521 is on a distinguished road
Default Question on gas
On 9/15/11 I purchased a brand new 2011 Ram 1500 Tradesman, with a 5.7 Hemi. Filled up only once so far. Used 89 octane with ethanol. My manual say 87 octane is acceptable, 89 octane is preferred. All the gas stations close to me have ethanol in their 87 & 89 octane gas. But on my way to work, there are a few stations that have 87 octane with out the ethanol.
So, why is 89 octane preferred over 87 anyway? And if I used 87 with out the ethanol, would I notice any difference (less MPG, etc.)?
Thanks for your thoughts guys,
Don <><
Old 10-04-2011, 07:54 PM
JasonK94Z JasonK94Z is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Quad Cab Outdoorsman
Rep:30
JasonK94Z is on a distinguished road
I dont think it makes any difference. If so, it would sure be hard to tell. 87 with ethanol in my tank every time. No problems here at all.
2011 Dodge Ram Quad Cab Outdoorsman
Old 10-05-2011, 01:30 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
89 octane allows the computer to not have to pull as much timing to avoid pinging. In some cases though even with 89 the computer will pull timing so you have to go 93
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 10-05-2011, 01:48 AM
Rep:2657
if you live in flat land country
87 octane will work good for you
if you have low RPM pinging, it is ok
if you have higher RPM pinging, you need to jump up to 89 octane
as far as ethanol is concerned, if you put in more than 10% ethanol, your warranty won't cover your Ram engine
Old 10-05-2011, 08:36 AM
Rep:32
Would it hurt anything if I used 93 octane all the time, and would there be any benefit? Or would I just be wasting my money? Usually, the 93 octane around here does not contain any ethanol.
Don <><
Old 10-05-2011, 09:46 AM
bowieknife's Avatar
bowieknife bowieknife is offline
Vehicle: 2013 Sport CC, 5.7L, 8spd
Trim Level: Sport Crew Cab
Rep:71
bowieknife will become famous soon enough
Send a message via Yahoo to bowieknife
I've actually been experimenting with 89 NON-ethanol gas to see if there was any MPG difference. There is not. I'd say the truck runs a little better and has a little more pep out of the gate, but not to justify the $4.19 price they want around me. 89 with 10% ethanol is the cheapest, best way to do it. IMO
Old 10-05-2011, 10:01 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Ethanol has a lower BTU content than gas, so (at least on paper) 87 non blend could perform better than 89 with ethanol. As an example, the new 4.7 Ram get 13/18 mpg on gas, 9/13 on E85!
Running 93 all the time won't hurt anything but your wallet!
Old 10-05-2011, 10:12 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
All the previous posts seem dead on....they recommend 89 octane because of the amount of compression and timing advance in the engine....87 will not hurt the engine, but if the knock sensor sees pinging/detonation it will retard timing and you will lose some mpg/performance. Some people say they get much better mpg/performance with the higher octane and some say they don't notice a difference, you'll have to experiment. Some say they even see better results with 91/93 octane as well, but I think that's usually not the case. Running a higher octane than required will never cause damage, but will cost more. You should run the lowest octane you can without causing pinging and loss in performance/mpg (to get the most for your money). I would definitely recommend ethanol free gas, you WILL get better mpg and peformance with it, like he said above ethanol has less energy per volume than pure gasoline.
Sean
Old 10-05-2011, 11:41 AM
Rep:24
From all my years playing with unnaturally aspirated engines, I've learned that not only does the octane rating stated on the pump differ, but what brand of station. I've had great performance with Arco, and absolutely crappy with Texaco and Shell.
The reality is that 87 will suffice for the vast majority of drivers.
Old 10-05-2011, 12:03 PM
snrusnak's Avatar
Rep:1385
^that's true, just because it says "87", doesn't mean you get 87....also, just because it says "up to 10% ethanol", doesn't mean it's not more than 10% ethanol...Some stations around me have been busted for purposely not providing what they advertise, others fined for doing it on accident.
Sean
Towing and Winter rim question Dubyeh Towing 6 08-14-2011 02:25 PM
Bumper Swap Question AKRAM Body & Interior 3 05-24-2011 11:10 AM
2010 headunit change question ddtb2010ram Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 03-23-2011 03:06 PM
Need FAST help!! Noob question!!! kmarshall32 5.9L V8 Specific Topics 8 09-16-2010 12:32 AM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
