Old 10-05-2011, 12:12 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
^that's true, just because it says "87", doesn't mean you get 87....also, just because it says "up to 10% ethanol", doesn't mean it's not more than 10% ethanol...Some stations around me have been busted for purposely not providing what they advertise, others fined for doing it on accident.
Yup. I can remember with horror running Shell 93 and having massive detonation under low boost- to the point I parked the car, went and got 5 gallons of Trick unleaded 101 to bring the octane up.
Old 10-05-2011, 12:26 PM
herc herc is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
herc is on a distinguished road
Flex-fuel cars and trucks take roughly 1.4 gallons of E85 to go the same distance as they could go on 1 gallon of gas. The ethanol actually ADDS a little (tiny) bit of power, but the energy content (BTUs) is only 2/3 of what's in gas. So, you don't lose power (in theory), but you DO use more fuel.
Applying that same logic to 10% ethanol gas says that you'd HAVE to lose a little bit of MPG. If you need an extra .4 gallons when the ethanol percentage is 85, then you'd need an extra .05 gallons if you have 10% ethanol. So, if you get 16 on pure gas, in theory you'd get about 15.25 on 10% ethanol.
Our hemis aren't flex-fuel, and there's lots of variables involved, but for those that think they get better "performance" on pure gas, I wonder if it's real, or if it's because there's a little more pedal needed. Dyno tests I've seen (on FFVs) show no power loss with E85. As I said before, power actually goes UP, but by such a tiny amount that you wouldn't notice it. It'd be real interesting to see an actual dyno comparison on the hemi using pure gas vs. 10% ethanol.
Old 10-05-2011, 12:34 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Our hemis aren't flex-fuel, and there's lots of variables involved, but for those that think they get better "performance" on pure gas, I wonder if it's real, or if it's because there's a little more pedal needed. Dyno tests I've seen (on FFVs) show no power loss with E85. As as said before, power actually goes UP, but by such a tiny amount that you wouldn't notice it. It'd be real interesting to see an actual dyno comparison on the hemi using pure gas vs. 10% ethanol.
I'm by no means an expert on fuels and ethanol....but I believe ethanol could be a decent fuel source however running it in an engine that is designed around gasoling does not justify it. I think ethanol has a very high octane rating (near 100 octane), so if you designed the engine with high compression and more timing advance, you could probably get more power out of it at the same cost for filling up the tank....I bet the dyno's you've seen that don't show power loss were tuned with more timing advance to take advantage of the ethanol's higher octane...
Ethanol free gas does get you much better mpg....my brother had a nissan sentra right before ethanol was introduced into fuels, and it was rated at like 40mpg hwy/30mpg city or around there...and it got it. The next model year ethanol was introduced and his 1 year old car was then suddenly getting 30-35 mpg hwy at best, and like 25-30mpg city. They have redone the ratings for mpg for vehicles due to this, and most have probably noticed that they have dropped...also my old s10 would get up to 30mpg on the hwy at slower speeds, after ethanol was introduced, 26mpg was the highest I ever saw after that, and that was on one trip, usually it was more like 22-24mpg.
Sean
Towing and Winter rim question Dubyeh Towing 6 08-14-2011 02:25 PM
Bumper Swap Question AKRAM Body & Interior 3 05-24-2011 11:10 AM
2010 headunit change question ddtb2010ram Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 03-23-2011 03:06 PM
Need FAST help!! Noob question!!! kmarshall32 5.9L V8 Specific Topics 8 09-16-2010 12:32 AM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
