Old 10-04-2011, 11:17 PM
cody0707 cody0707 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
cody0707 is on a distinguished road
Default Y-pipe
Does the 2008-??? have a Y-pipe?
If so where is it located, where the headers come together in a single exhaust?
If it does have one is it benificial to have it replaced with a aftermarket one?
Which one?
So far: Removed B-pillar tape, Debadged, 15% tint, 55w 6000k HID, 2" leveling kit
Old 10-04-2011, 11:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Yes it does and it is where the two 2.5" down pipes from the exhaust manifolds merge together to one 3" single exhaust pipe. Yes it is restrictive and benefits (performance wise) to an aftermarket/custom one. The magnaflow stamped y pipe is great and cheap for the part(like $30) but you need to have it installed also...
Sean
Old 10-04-2011, 11:25 PM
Rep:20
Sean thanks for the help. I guess when I take my truck in to have the exhaust done I will get one of these and have them do it as well. Planning on going with a Magnaflow with possibly single to dual exhaust, not real sure though.
Old 10-04-2011, 11:29 PM
snrusnak's Avatar
Rep:1385
No problem, if you want the look of duals then cool, but if it's only for performance there isn't any real benefit to going to duals, just do a single in/single out 3" exhaust all the way back(can just swap the muffler as the stock exhaust is 3")...all depends if you want the look of the duals and tips and all that though...If you go duals I would go with 2.25" dual pipes, 2.5" at the largest.
Post back with what you end up doing
Sean
Old 10-08-2011, 11:38 AM
Nutsandboldts05 Nutsandboldts05 is offline
Vehicle: 2014 Dodge Ram
Nutsandboldts05 is on a distinguished road
My truck came with a single in dual out exhaust and I love it. Maybe I should grab myself a Y-pipe if it doesn't have one. When you say "...but you need to have it installed also..." did you mean a shop should do it, instead of doing it yourself? Or, was that just a friendly reminder that the $30 is only the initial cost?
Old 10-08-2011, 02:44 PM
BigOrange BigOrange is offline
Vehicle: 2013 RAM 1500
Trim Level: EXPRESS QUAD CAB
Color: BRIGHT SILVER
Rep:17
BigOrange is on a distinguished road
the part is around $30, but unless you are a welder & have a pipe bender, you will need to have an exhaust shop fab up the proper piping & weld it in.
Magnaflow 14" SI/DO, No Resonators, K&N Drop-In Filter, De-badged.
Old 10-08-2011, 06:47 PM
snrusnak's Avatar
Rep:1385
^yeah, pretty much need it welded in. Blackramhemi posted a way with some mandrel bends and clamps but IMO it's the same price roughly to get it welded in so might as well just do that...
Sean
x pipe and y pipe together? homerkill Exhaust 5 07-29-2011 05:38 PM
X Pipe and High Flow Cats texasd18e Exhaust 2 10-29-2010 10:02 PM
2010 ram hemi hp# 440 modded, x pipe or h ? SPEEDFREAK Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 24 07-08-2010 11:34 AM
x pipe for ram superdodge33 Dodge Ram General Discussion 0 04-02-2009 06:46 PM
Y Pipe ram06bighorn Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 01-09-2009 06:00 PM
