Biggest tires without lift? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-05-2011, 07:10 PM
Mumauber's Avatar
Mumauber Mumauber is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: Quad Cab SLT
Rep:27
Mumauber is on a distinguished road
Default Biggest tires without lift?
I have an 06 Quad cab with 245/40/r17 tires at the moment. What is the biggest tire I can put on it without it rubbing when I turn, or adding a lift kit? Thanks in advance for any info.
2010 Journey R/T
2006 Ram 1500 SLT
Old 10-06-2011, 03:44 PM
DuckandDodge05 DuckandDodge05 is offline
Vehicle: 2005 Dodge Ram
DuckandDodge05 is on a distinguished road
I've seen 35's on an 06 ram with no lift or leveling kit before, there was a lot of rubbing though, and a bunch of wear and tear. You could probably run 33's, but will still have a little rubbing. With a 2 inch leveling kit and 33's you'd be good. But probably a set of 275's (31's) are going to be the biggest you can run comfortably
Old 10-07-2011, 01:36 PM
Mumauber's Avatar
Rep:27
Talking
Thanks, I've searched all over for the internet for that answer, but found nothing.
2010 Journey R/T
2006 Ram 1500 SLT
Old 10-07-2011, 01:47 PM
Twisted10's Avatar
Twisted10 Twisted10 is offline
Vehicle: 2012 Dodge Ram QC 4wd
Color: Mineral Gray
Rep:25
Twisted10 is on a distinguished road
35's but u cant go w/ 35x12.5's or they will rub i believe.
u need to find a 35 that is 11 or 11.5 wide.
33's come stock on them w/ 20" wheels, so i know 35's will fit, its the width you have to worry about.
Old 10-07-2011, 01:50 PM
Truly, width is more of an issue than height. But I agree, a 275 section width tire will work. I'd be a bit concerned about a 33" tire rubbing on the leading or trailing edge of the fenders.
4" Lift and 35" Tires Question?!?!?!? RFarruggia Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 07-31-2011 09:19 AM
biggest tires stock 94 1500 94muddigger Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 05-15-2011 05:22 PM
Comparison Photo's - Tire Size & Lift Quiet Lunatic Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 30 03-14-2011 05:59 AM
New member - Question on tires and lift kit rjh1500 Newbie Checkin! 12 07-22-2010 04:52 PM
Biggest tires I can fit?! tburton101 Dodge Ram Wheels And Tires 3 02-21-2010 04:19 PM
