Old 10-05-2011, 07:41 PM
08ramKING's Avatar
08ramKING 08ramKING is offline
Vehicle: 2008 dodge ram 1500
Trim Level: leather
08ramKING is on a distinguished road
Unhappy Steering Stabilizer+Bracket HELP!!!
Okay so I have a 2008 ram 1500 laramie. It has a 3" body lift, 2.5" leveling kit+1.5'' blocks and shocks in the rear, 35'' tires. Since I put the lift and tires on I have noticed a small wobble and drift when driving(death wobble) and I wanted to install a dual steering stabilizer and wanted to install a stabilizer bracket also to solve the wobble problem. My question is what a good dual stabilizer kit for my truck and where can I find a stabilizer bracket??? I hear PSC makes a good bracket but for some reason they don't sell it for 2008 ram 1500. Or do they not sell it cost it's not needed after I install the dual stabilizer cause that will solve my wobble issue. PLEASE help me, I'm at a dead end with this.
Old 10-06-2011, 06:39 AM
scottd53 scottd53 is offline
Vehicle: 2007 ram sport
scottd53 is on a distinguished road
i have never seen a steering stabilizer for rams with independent front ends....
Old 10-07-2011, 09:23 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
^^^^Exactly^^^^
Old 10-08-2011, 12:22 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:275
A steering stabilizer would mask the problem. Primary cause of death wobble is a bad alignment, bad ball joints and bad unit bearings.....in that order. Take it to a good shop and fix the issue, don't cover it up.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 02-16-2012, 06:44 PM
08ramKING's Avatar
Trim Level: leather
Is there anyway to make a stabilizer fit on a 1500 for having 35's. The big tires tend to jerk the wheel and a damper should do the truck but im confused on how to custom fit this
Old 02-16-2012, 07:28 PM
atlas135's Avatar
atlas135 atlas135 is offline
Vehicle: 2006 Dodge Ram
Rep:13
atlas135 is on a distinguished road
Here is what I am getting on mine. I agree with battlerattle though, fix the problems first. The stabalizer will help for the hardcore off road stuff and it looks cool. http://bds-suspension.com/product-display?all
2006 Ram XLT, 5.7L HEMI, BDS 6inch lift w/Fox shocks, 35" Terra Grapplers
Old 02-16-2012, 07:53 PM
08ramKING's Avatar
Trim Level: leather
I miss spoke, its not technically a death wobble, more of a jerk of the wheel with big bumps. I figured a damper should correct the problem? is there a way to custom fit the damper to the frame and tie rod with proper clearance. has anyone had this problem?
Old 02-16-2012, 08:34 PM
atlas135's Avatar
Rep:13
I am having mine installed sometime next week. I can take pics and send them to you if you would like.
Old 02-16-2012, 09:32 PM
08ramKING's Avatar
Trim Level: leather
that would be great! dumb question, you have a IFS right? not a solid axle.+ i think BDS makes stabilizers for the lifts only.
Old 02-16-2012, 10:29 PM
atlas135's Avatar
Rep:13
It is IFS, however I am not sure if the BDS kit fits just lifts or not, but I will let you know. I did order it with my lift but it came with the wrong shocks, so it should be good to go next week. It is good to drive it without so I can compare.
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
96 1500 4x4 Steering Stabilizer mjonesjr Suspension 3 07-25-2010 07:56 PM
Steering Stabilizer issue... alfonso318 Suspension 5 07-22-2010 10:21 PM
Remerson228 last airbag question awful knawful 2009 Dodge Ram Forum 5 05-17-2010 07:42 PM
Steering stabilizer torp74 Suspension 8 01-09-2010 10:52 AM
