Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 10-05-2011, 10:37 PM
cobra989 cobra989 is offline
Vehicle: 2003 Dodge Ram 1500 SLT
cobra989 is on a distinguished road
Default weird engine issue
Hey guys,
sorry i havent posted in a while.. got busy with a side project(1971 Saab Sonett III)... anywho. I have noticed this issue a few times and reading some of the other threads around here I am getting a little worried... Sometimes when I start the truck doesnt matter if its cold outside or warm, my truck sounds funny... I know big help right? It sounds like I have an extra fan running and my engine seems to be a little sluggish. I just started the truck and I hear a little bit of ticking but it quickly goes away, opened the hood up and I can definaetly hear the lifters working... I can also smell a heavy odor of gas/exhaust fumes... Did any of this provide any help in describing any known issues? I hope that someone can help!
Old 10-06-2011, 12:36 AM
02Ram4x4 02Ram4x4 is offline
Vehicle: 2002 Ram
02Ram4x4 is on a distinguished road
the extra fan sound could be your fan clutch, does it go away after driving it a bit?, also the gas fume smell could be a rich mixture/exhaust leak, which the leak could cause both a rich mixture and a tick sound, use a mechanic stehoscope to pin point the sound.
Old 10-06-2011, 08:53 PM
yea after I drive it for a while the sound goes away... I didnt think about the fan clutch and I forgot to mention that I got a engine light a few month ago and it had to do with the evap system and I think the error was for the evap canister(?) on the drivers side of the cab underneath. Do you think that could be the cause of the gas smell?
Old 10-06-2011, 09:18 PM
1miracle2's Avatar
1miracle2 1miracle2 is offline
Vehicle: 2007 Dodge Ram Quad Cab 4x2
Trim Level: SLT Quad Cab 4x2
Rep:103
1miracle2 will become famous soon enough1miracle2 will become famous soon enough
Do you have the same engine as mine that can run on that e85 biofuel? If so I read in the manual book that this could happen. I would refer to that book if I were you, I'm sorry I don't recall what you need to do if any thing or exactly what it was, but there was some thing in there stating this could happen. If you're using the e85, the mixture maybe off or some thing? IDK, sorry, not much help right!
It ain't your's until it's custom!
Old 10-06-2011, 11:59 PM
lol its ok, I dont have an owners manual so Im not sure. I have the 4.7L but I am not sure how to check and see if I have E85 compatibility. Its a good thought though, ill look into it for sure!
Old 10-07-2011, 12:56 PM
1miracle2's Avatar
Rep:103
You'll have an e85 decal of some sort some where on the truck. Unless it's a purchased used truck that some one could have removed it?
You can always go to Autozone and buy a fuel cleaning kit? Maybe needs a tune up? You know... Spark plugs, Airfilter, fuel cleaning kit, check cracks for gas cap and maybe an oil change?
Good luck bro!
Old 10-17-2011, 10:26 PM
Vehicle: 2002 Ram
yes if your canister is saturated with fuel you will smell fuel, that canister is full of charcoal and is used to send unspent fuel back to the engine to be reburnt, and if it doesnt purge correctly if will back up and you will smell fuel from time to time!!
Old 10-25-2011, 10:35 AM
now i feel like a dummy because i got the error code for the canister and i just cleared the code thinking it was my gas cap... which truth be told was in crappy condition anyways. Does anyonw know where I can get the canister and how to install?
Old 10-25-2011, 10:06 PM
Vehicle: 2002 Ram
most autopart stores should have it, price im not sure!, but it should not be superexpensive. No need to feel stupid, all of us have to ask ourselves questions like does has the truck got fuel!!! no pun intended
Old 10-25-2011, 10:12 PM
Vehicle: 2002 Ram
Belay my last post i checked autozone its a vapor canister under engine management and its 114 bucks, youch.. i make sure thats the problem, like take the old one off, and shake it!!!!
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
Purpose of Engine Cover? Cai Installed! RammD Dodge Ram General Discussion 11 08-04-2010 07:05 PM
Couple Of quick tips when doing DIY on your engine Dann Dodge Ram General Discussion 23 12-26-2009 06:03 AM
Catastrophic engine failure!!! commmedic 2009 Dodge Ram Forum 24 09-17-2009 09:12 AM
