Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 11-16-2011, 10:17 PM
Krpto1973's Avatar
Krpto1973 Krpto1973 is offline
Vehicle: 2011 Dodge Ram 2500 4x4
Trim Level: Power Wagon
Rep:71
Krpto1973 will become famous soon enough
Default Loud Fan Noise When Engine Cold
Guys, just a quick question I have been meaning to post for a long time.
When I start up my truck on a cold morning, whether I let the engine warm up first or not, the engine makes a loud fan noise that gets louder as the engine RPMs increase, like the fan clutch, if there is one, that is not releaseing. It only does this on cold mornings, and only for a mile or two.
Is this normal, and if so, what exactly is the purpose.
Oh, and its a 2011 2500 Hemi.
-2011 Dodge Ram 2500 4x4 Power Wagon
-2006 Suzki GSX-R 750, 2004 Triton Tr-19x
Old 11-16-2011, 10:24 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
Mine did that right before my fan clutch went out and stuck on all the time. Made my truck sound like a Jet was taking off..
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 11-17-2011, 11:24 AM
Krpto1973's Avatar
Rep:71
Yeah, thats exactly what it sounds like. I had that problem in a Chevy once too and the fan clutch out and had to be replaced. BUt this truck has been doing it since I got it (on cold mornings), so I thought it was just intentional. I have been in Florida in the warmth for the last 7-8 months, so it wasn't doing it. I just came north were its cold in the morning, and now its back.
Old 11-17-2011, 01:59 PM
nfllover911 nfllover911 is offline
Trim Level: Longhorn
Color: Sagebrush
Rep:17
nfllover911 is on a distinguished road
This happens to me as well I am pretty sure its normal though.
Old 11-17-2011, 02:04 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
I posted a similar question about the fan clutch on the boards a while back and I was told it was normal. But, in my lifetime, I've never had a fan clutch engage when the engine was cold right at startup, unless it was bad And you're right, it only does it on cold mornings. Seems that the behavior is the opposite of what you'd expect, right?
Mine seems to unlock after less than a mile of driving and then it operates normally as far as I can tell.
Anybody have some insight into this? Just doesn't make sense to me either.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2012 Jeep Grand Cherokee Limited
Old 11-17-2011, 03:01 PM
Krpto1973's Avatar
Rep:71
Yep, that seems exactly like my issue. I would love it if someone could tell me exactly what is going on so I can quit worring about it everytimr it happens, or get it fix if it needs it.
Old 11-17-2011, 03:05 PM
Rep:1388
Why don't you try asking the dealer? I don't know a lot about mechanical fan clutches, but I do think the newer ones are somehow electronically controlled aren't they? And wouldn't you expect it to be locked at startup, low rpm, when the clutch should be locked and fan spinning (as there is no air movement through the radiator at low rpm/idling. I don't know just seems logical to me...
Old 11-17-2011, 05:26 PM
Rep:87
when i went in my service adviser ( who was not my normal guy) told me that everything sounded fine. when I asked to talk to a tech we went out to the lot and started 3 other trucks none sounded like mine so he replaced the fan clutch and on the service sheet the tech put "sorry for the run around , but we now know what to fix when people are complaining about the noise."
Old 11-17-2011, 08:47 PM
Krpto1973's Avatar
Rep:71
Well if the response is going to "why don't I talk to the dealer"... then what’s the purpose of this board. Maybe we should just make the board respond with automated reply’s to go talk to the dealer? I thought it was to get opinions and answers from other people that have experienced similar problems so that we can educate ourselves. Personally, I would like a little background information on what the problem might be ahead of time, so that when I do go talk to the dealer, I can speak intelligently about and don't get the run around.
Last edited by Krpto1973; 11-17-2011 at 09:43 PM. Reason: Cause I can't spell to save my life.
Old 11-17-2011, 08:57 PM
Rep:87
here is the thread that I had started about this and some of the feedback/answers that helped me out.
http://www.ramforumz.com/showthread.php?t=88388
