Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-05-2011, 11:20 PM
DirtyD's Avatar
DirtyD DirtyD is offline
Vehicle: 03 2500
Color: Gray
Rep:45
DirtyD is on a distinguished road
Default lift question ( 05 ram )
I would like to clear 37's on my 05, ( just like everyone else, lol ) now can i do that with just a 6" lift kit? ive seen some do it and ive seen some where it looks like 35" are the max, the rims i will be running are AX184 Justice with a Back Space of 5.47 and a Offset of 12.
03 2500 ( Hemi ), 8" lift and 38" Toyo Open Country M/T
Old 10-06-2011, 03:41 PM
DuckandDodge05 DuckandDodge05 is offline
Vehicle: 2005 Dodge Ram
DuckandDodge05 is on a distinguished road
A 6 inch might work, but you're more than likely gonna have a lot of rubbing. If you can, try a 6 inch lift and maybe a 3 inch body lift. That way you'll clear them and look nice, without rubbing. I run 38's on my truck right now, and before that I had a set of 37s and I had was a 5.5 inch suspension and torsion bars that were cranked up so it sat about about 7.5 inches. I also had 2.5 inch add a leafs and the 37's fit perfect without rubbing. Hope this helps!
Old 10-06-2011, 03:57 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
do you have any pics of these set ups?
Old 10-06-2011, 04:14 PM
I'm new to this whole forum, so I'm not sure if you can see my pics. But I'll put up a pic of my truck when I had it on 37's
Old 10-06-2011, 04:17 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
ok cool, what part of Ga r u in?
Old 10-06-2011, 04:20 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
With an offset of 12 you will probably have to get wheel spacers to get them to fit. What size are you thinking? 37x13?
I would try to steer clear of body lifts, they ride way too rough, especially offroad.
Dillon-aka, The Little Kid
Old 10-06-2011, 04:26 PM
Macon/warner robins. Pretty close to the air force base lol
Old 10-06-2011, 04:29 PM
Body lifts do ride rough. I have a 3 inch in mine, but it's really not terrible. Could be smoother, but it's not that bad with the right suspension I guess. lol
Old 10-06-2011, 04:55 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
Body lift don't have anything do with with how your truck rides, all it does is lift the body, it doesnt do anything to the susp. my friend has a 02 with a 3" BL and it rides just as like mine. well his is a little rougher but he also has like a 12" susp lift on it.
2008 2wd 1500 procomp 6" knuckle/crossnember lift question deervalley Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 01-10-2012 11:58 PM
3 inch body lift question on a 87 power ram pirayaman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 04-14-2011 03:15 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Spindle Lift Question!! goodjohnson Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 01-27-2011 01:46 PM
body lift question? pullin48 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 05-13-2010 02:08 PM
