Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 10-06-2011, 12:38 AM
jacruz2 jacruz2 is offline
Vehicle: 2014 Ram 2500 Mega Cab
Trim Level: Laramie Mega Cab
Color: Max Steel
Engine: 2013-2014 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:17
jacruz2 is on a distinguished road
Default Headlight issue
Hello forumers
I'm in need of some help my passenger headlamp is out both low and high (quad lights) so I tried changing the bulbs with no joy. I would take it to the dealer but I had HIDs and I had to drill a hole behind the plastic caps to run the wires threw and I'm afraid the dealer will just blame it on that instead of focus on my issue (the issue is with the standard bulbs pulled HIDs out before this problem). The parking lamp and signal still work and my EVIC isn't throwing any codes so I'm kinda at a lost at what to do.
I've also tried looking for those plastic headlight caps but I can't find a part number. So if you have any info on my issue or even know where I can find those caps or even the proper terminology I'd greatly appreciate it,
Thanks
Old 10-06-2011, 12:43 PM
moparornocar72's Avatar
Rep:630
I had a issue with my hids causing them to go out since the connection was loose, put the old light back in and still no dice. Try disconnecting the negative and then reconnecting it to re-set the connection. hope it works for you!
14.268 @ 95 MPH Full Trim
Old 10-06-2011, 09:57 PM
Color: Max Steel
Rep:17
I tried disconnecting the battery for 10+mins with no luck thanks for the advice.
Is there a difference in just disconnecting the negative also is there a way to see if the vehicle is throwing any codes on the EVIC?
I also tried pulling out the TIPM and checking the connections. I hate driving around with the one eye Willie I'm starting to hate this TIPM idea.
Old 10-20-2011, 12:35 AM
BlackJack's Avatar
BlackJack BlackJack is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4X4 Quad Cab
BlackJack is on a distinguished road
Default Help! with low and high beam issues.
I have the same problem. No low or high beam on the passenger side after I installed HID. I first tried it on the driver side only to see the difference between the two. Then installed the passenger side and turned it on and only the driver side lit up. Everything else works. Even tried to go back to the original lights and they don't work anymore either. Send me an email with the solution please. don_pr2003@yahoo.ca.
Old 10-20-2011, 05:16 AM
Color: Max Steel
Rep:17
I don't have a solution but I was able to buy those plastic caps that I drilled holes in and I'm waiting for them to come in. Once I get them in I'll take my truck to the dealer and I'll let you know what I find. Also if you find a solution before then feel free to post it up here.
A guy on another forum had this same issue and he was able to trace it back to a grounding issue but I tried to write him and ask him where but he hasn't responded to me and he hasn't logged on to his account in over two months.
Old 10-29-2011, 11:08 AM
bassbolt's Avatar
bassbolt bassbolt is offline
Vehicle: 2012 Ram Sport
Trim Level: Sport CC
bassbolt is on a distinguished road
Where did you find the caps? Part # ?????
1995 Diesel536HP;2004 Diesel523HP;2009 Challenger;2012 1500 Sport on order! Valentine One in all
Old 10-30-2011, 08:15 PM
Color: Max Steel
Rep:17
I wasn't able to get a part# but Jeremy from the
http://*************/index.html
Was able to help me out with two of them.
Old 10-30-2011, 10:44 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
With the headlights turned 'OFF', when you go to start the truck and turn the ignition switch to the on position, do both the low beam headlights come on?
brad
Interested in one of my mods?
Old 10-30-2011, 10:54 PM
BlackJack's Avatar
No they do not go on when the light switch is in the off position on start up. If they are in auto yes they do. Well in my case the driver side until I get the issue resolved.
Old 10-30-2011, 11:15 PM
brad12kx's Avatar
Rep:2581
This start up sequence is separate from the information from the headlight switch, so if the condition is the same, then the problem is either in the TIPM, or in the wiring from the TIPM. If you have a code reader, there may be a deep code that suggests the TIPM is in protect mode (although this should have reset when you disconnected the battery cable), or the TIPM has lost some of it's programming, or the TIPM has failed.
Have you check the headlight connector to make sure none of the wires have pulled part way out and subsequently are not making proper connection on the bulb? I have seen this scenario many times, so it's worth checking out.
brad
2007 Ram Headlight issue crogers1 Electrical 3 06-16-2012 10:07 AM
Headlight switch issue ! DodgeGuy85 Electrical 10 09-29-2011 06:32 PM
New headlight problem. Need help. Harness Issue. hemisport09 2009 Dodge Ram Forum 1 03-30-2011 10:04 AM
Halo Projector Headlight Issue. Has anyone else had this? BigHornRam2006 Custom Dodge Ram Interior and Exterior Lighting 5 03-18-2011 01:35 PM
ABS/Brake Light....headlight issue too! BigTimmy03 Electrical 6 01-28-2010 06:02 PM
