Old 12-16-2011, 10:25 PM
BlackJack's Avatar
BlackJack BlackJack is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4X4 Quad Cab
BlackJack is on a distinguished road
I guess they wouldn't have much of a choice but to replace it under warranty. I am lucky that I get along with the dealer. Now that they see the HID's running in the truck they can't turn around and say that it is related to it as if it was the TIPM would have burnt up instantly after turning the key. I used fat digital 35W ballasts and the decoder relays with 6000K lights all from Recon truck accessories as for Ryan Quinn he will help you get set up for low beams or your fogs.
Old 12-16-2011, 10:30 PM
BlackJack's Avatar
I was told by the mechanic that the TIPM connections corrode with time and for that reason pull more amperage and burn up circuits as the TIPM enclosure is not very good to protect it from the elements. So I had an anti rust corrosion inhibitor sprayed before having the TIPM installed.
Old 12-18-2011, 02:25 AM
jacruz2 jacruz2 is offline
Trim Level: Crew Cab Sport
Rep:17
jacruz2 is on a distinguished road
Alright well I guess I'll put back in my HIDs and pray for the best I hope my dealer doesn't give me crap if it goes out again. I just don't see how they replace a faulty part with a part that has such a short shelf life. So does this meant that every two years I'll have to replace my TIPM? It just doesn't make sense to me its like putting a band aide on a bullet wound sure it does the job for now but in the long run were screwed.
I hope they're not just waiting till my warranty runs out then I have to come out of pocket for Dodge.
Old 07-13-2012, 05:02 AM
bigredh2's Avatar
bigredh2 bigredh2 is offline
Vehicle: 2009 Dodge Ram 1500 Hemi
Trim Level: Larmie
Color: Ruby Red
bigredh2 is on a distinguished road
Default No passenger light
hi guys I just had this problem on my 09 Ram. Do you have any idea on warranty details to be covered? I'm waiting on my replacement cap to come in and I'll take it to the dealership
Old 07-17-2012, 01:48 AM
mrtosh mrtosh is offline
Vehicle: 2014 dodge ram
Rep:12
mrtosh is on a distinguished road
Man, this is kind of a scary read. Was this problem only inherent to'09's? I want to run a Retro solutions HID kit on my 2012 but am having second thoughts after reading this. Will I have any issues?
Old 07-09-2014, 10:12 PM
Bakeapple Bakeapple is offline
Vehicle: 2012 Ram 3500
Trim Level: larimine
Engine: 2011-2012 409ci (6.7L) Cummins Turbo Diesel 350hp 800lb/ft
Bakeapple is on a distinguished road
Default Ram 2012 Headlights
Both my low and high beam light are not working. It is stock and only has 60000Km(38000 milies). Anyone else have this issue with the 2012 3500 Cummins
2007 Ram Headlight issue crogers1 Electrical 3 06-16-2012 10:07 AM
Headlight switch issue ! DodgeGuy85 Electrical 10 09-29-2011 06:32 PM
New headlight problem. Need help. Harness Issue. hemisport09 2009 Dodge Ram Forum 1 03-30-2011 10:04 AM
Halo Projector Headlight Issue. Has anyone else had this? BigHornRam2006 Custom Dodge Ram Interior and Exterior Lighting 5 03-18-2011 01:35 PM
ABS/Brake Light....headlight issue too! BigTimmy03 Electrical 6 01-28-2010 05:02 PM
