Old 10-11-2011, 12:30 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Stock carb intake or tbi?
Old 10-11-2011, 09:44 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
tbi in 89 they came with tbi injection
-IF YOU CANT DODGE IT RAM IT!!!!
Old 10-11-2011, 11:34 PM
Rep:99
I know that, but you're assuming we automatically know what vintage your "Dodge 318 la" is. I'm asking because I'm curious as to your particular solution to the bolt pattern incompatability between the offset Mopar intake tbi pad and both the old 4-bolt 670 Pro Jection or the new 3 bolt Avenger model.
Old 10-12-2011, 09:58 PM
89powerram's Avatar
Trim Level: Slt
its the 4 bolt with stock manifold and round air intake
Old 10-12-2011, 10:48 PM
Rep:99
Then it's not a 670. If it's a stock 318 tbi intake, it has an offset bolt pattern. The tbi was made by Holley, but it's more like half the flow of a 670, I don't remember the exact number. The 360 tbi is around 600 cfm and will fit the same bolt pattern (unique to the Mopar tbi as far as I know), but the throttle blades are larger and will hit the 318 manifold unless opened up with a grinder. The same era V8 GM tbi 4-bolt pattern was a typical pattern you'd see with a 2 barrel carb. Sorry chief. Hate to be a downer.
Old 10-12-2011, 11:19 PM
89powerram's Avatar
Trim Level: Slt
i think its a 4 bolt i will have to check i know that my grandpa ordered the tbi out of a catolog and the box says performance 670cfm i will check tmro to make sure
Old 10-12-2011, 11:28 PM
89powerram's Avatar
Trim Level: Slt
just looked it up holley doesnt make any thing below 650 cfm in throttel bodies
Old 10-13-2011, 02:52 AM
Rep:99
You're confusing aftermarket with OEM, as the stock V6 and 318 were definitely smaller than 670. Now if you have an aftermarket tbi, it may indeed be a 670, but it wouldn't fit without some sort of adapter. If you have an aftermarket 670 tbi with a Mopar-specific offset bolt pattern for use on a stock manifold, well that would be a rare bird. Interested to see what you find. Mopar offered the 360 tbi as part of a performance upgrade for the 318 back then. It included a template for opening the intake to clear the larger throttle blades. Kit included 360 computer and a Flowmaster muffler. Wonder if that's what you have?
Old 10-13-2011, 09:34 PM
89powerram's Avatar
Trim Level: Slt
it has the dual flowmasters im goin to look it over tmro i had to have an accelorator cable put on it but ive had a truck like this before and this one has a shit load more power than the other
Old 10-13-2011, 09:57 PM
89powerram's Avatar
Trim Level: Slt
problem solved it is a holley universal tbi 670 cfm and in the box that the tbi came in was a box to an adapter than allowed you to bolt it on
