Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Dodge Ram Decals
Old 10-07-2011, 05:23 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
Default regular cab rear window question
i was cleanin the truck windows last night and i noticed that the felt piece under the rear window with the rubber strip running across the top of it doesnt seem to be on correctly. if i look at both corners this piece is butted up against the window but the rest of it is away from the window and it shows the sealant they have holding the window in place. under the rubber piece there is a lip which seems like it should hook over the lip on the metal under the window. my question is does this panel hook over the metal lip under the rear window and have the rubber strip rest against the window or does it just sorta sit away from the window?
Old 10-14-2011, 11:45 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, don't have an answer, but I can offer to this back to the top!
How do I disable the rear sliding window. persuazion LD RAM - General Discussion 7 03-20-2015 11:13 AM
Rear Passanger Window not rolling up tvw74 2010 Dodge Ram Forum 2 10-01-2011 02:44 AM
Rear window question stubie82 Body & Interior 2 07-17-2011 08:40 PM
Rear window leaks StormTrippinFiVe9 Body & Interior 3 02-22-2011 02:14 PM
Sliding rear window vs fixed window w/ defroster ronnchy LD RAM - General Discussion 5 10-04-2009 10:28 PM
