Old 10-07-2011, 02:07 PM
SMOKINGRT SMOKINGRT is offline
Vehicle: 2011 dodge ram
Trim Level: rt
Color: grey
SMOKINGRT is on a distinguished road
Default Lowering
thinking about lowering my new 2011 ram, any one have any advice on what parts i need or which way to go? not trying to spend 1000$ on a body drop, just trying to get something quick, advice any one??
Old 10-07-2011, 02:43 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
You can cut a coil or so from the rear and it'll level out the back. A few people have done that here with great success. Ground Force makes a 2 inch rear drop kit for around 300 dollars, I've seen 2/4 drop kits for around 500 bucks. IMO I think the 2 inch rear drop looks the best. The front is low enough from the factory.
Old 10-07-2011, 03:01 PM
P Rod's Avatar
P Rod P Rod is offline
Vehicle: 2011 Ram 2wd Crew Cab
P Rod is on a distinguished road
I would recommend doing the right thing and buy a complete kit, with the proper engineered shocks and springs. You will be happy you did. The truck will ride much better that just cutting or adding shorter springs. Ground Force 2"/3" drop is what I put on my Ram Crew Cab. I am very happy with it. Bell Tech also makes a very good 2"/4"complete kit but heard on this forum they are on back order till Dec. McGaughy's makes a 2"/4" drop but I don't think they come with new shocks. If you can, buy a good kit and save money by doing the work yourself. It is not very hard if you follow instuctions well. Remember to add another $90-$110 for an allignment. Good Luck.
I just seen this deal on Ebay for a new GF kit for your truck. Very good price. http://cgi.ebay.com/ebaymotors/09-10...-/280737073874
CrewCab Sport*Sunroof* Navi*3.92's*Ground Force 2/3 drop*Back Flip F1*Mufflex 18"*BedTred
Old 10-07-2011, 04:02 PM
Bell Tech makes a good kit.
Old 10-08-2011, 10:58 AM
Lie2me Lie2me is offline
Vehicle: 2011 CC 2wd
Rep:26
Lie2me is on a distinguished road
I like my 2/4 with shocks from Belltech. I have to agree on the front being low from the factory. I still get rub up front when I'm at full turn, nothing major though. I would also factor in a set of helper bags($85) if you ever plan on towing or putting anything in the bed. The 4" drop on the rear at times seems lower than the front. I'm only getting the bags because I may have to haul a load of crap here soon, maybe a trailer and a full bed of in-law possessions.
Old 10-08-2011, 10:59 AM
Rep:26
I'm actually hoping that the bags give me a small lift in back.
Old 10-08-2011, 12:51 PM
Trim Level: rt
Color: grey
Sounds pretty good, I might as well go the extra buck to get something that's worth it, ive been looking for some of the parts but a lot of manufacturers show only up to 2010 models, is it any different from mine being a 2011 or could I use those parts??
Old 10-08-2011, 04:32 PM
Lightemup's Avatar
Lightemup Lightemup is offline
Vehicle: 2011 Ram 1500 R/T
Trim Level: R/T
Lightemup is on a distinguished road
i dont what you guys are talking about the truck being low enough from factory. My R/T sat higher than a 4x4 from the factory...... i already installed a 2/4 Belltech drop, and i just picked up a set of 2 inch drop spindles from Mcgaughys. should be installing soon so it will have a 4/4 drop. so far it rides pretty good i had to cut the rear bump stops though, but its fine. Remember go low, go high, or go home!
MOPAR OR NO CAR!
Old 10-08-2011, 07:25 PM
Trim Level: R/T
Rep:60
Lie2me how does your truck drive with the drop? Let us know how it handles the load when you use it. I want to lower my truck but I cant decide on what kit or how low I want to go.
Final question before lowering 4G Lie2me 2011 Dodge Ram Forum 3 06-09-2011 06:58 AM
Lowering...suspension...brakes.... HEMI1980 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 05-22-2011 05:56 PM
DJM 3/5 lowering kit bransonshemi Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 12 12-24-2010 04:12 AM
Going from a lift to lowering..... thardy3 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 07-15-2010 07:31 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
